OS FS120S-E compression
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> OS FS120S-E compression
Page: [1]
Login
OS FS120S-E compression - 5/7/2008 1:19:35 AM
rs670
Status: offline
I purchased this OS FS120 new and have not run more than a couple gallons of fuel through it. Originnally, the compression seemed fine. Lately, even though it starts and runs good, the compression seems really low. When turning it over by hand, I can barely tell when it comes up on compression stroke. The throttle is open and valve clearance is OK. Is it possible the ring needs replaced already and is this something I can do myself with standard hand tools?
       Post #: 1
RE: OS FS120S-E compression - 5/7/2008 1:41:57 AM
Ken6PPC
Status: offline
I seriously doubt the ring is worn out that quickly. Try taking the glow plug out, dribbling some after run oil or automatic transmission fluid down the cylinder, and try it again. I bet your compression will come right back when it has some oil in the cylinder.
_____________________________
Club Saito Member #370
AMA #853194
(in reply to rs670)
       Post #: 2
RE: OS FS120S-E compression - 5/9/2008 3:34:49 AM
skorman
Status: offline
quote:
ORIGINAL: Ken6PPC
It sounds like the valves need to be adjusted. That can easily affect compression.
Steve
(in reply to Ken6PPC)
       Post #: 3
RE: OS FS120S-E compression - 5/9/2008 3:44:43 AM
Nathan King
Status: offline
quote:
ORIGINAL: skorman
quote:
ORIGINAL: Ken6PPC
I concur. This sounds like it may be a valve problem.
I have NO affiliation with Hobbico or any other model company. The fact that Hobbico hired a Nathan King is pure coincidence
(in reply to skorman)
       Post #: 4
RE: OS FS120S-E compression - 5/9/2008 4:30:04 AM
bigedmustafa
Status: offline
Nathan should know, he works for Hobbico!
To a tree, balsa wood and MonoKote taste just like chicken!
(in reply to Nathan King)
       Post #: 5
RE: OS FS120S-E compression - 5/9/2008 1:44:27 PM
rs670
Status: offline
I appreciate the replies about valve adjustment maybe causing the problem but, in my original post, I stated that there is valve clearance. If there wasn't any, I could understand compression being affected. "Too much" clearance on the other hand would affect performance but not compression. If my thinking is wrong, please straighten me out. Thanks guys.....
       Post #: 6
RE: OS FS120S-E compression - 5/9/2008 7:08:27 PM
Ken6PPC
Status: offline
No, you have it right. If you didn't have ANY clearance, the valves would never close completely. If you have too much clearance, you would still have compression.
AMA #853194
(in reply to rs670)
       Post #: 7
RE: OS FS120S-E compression - 5/9/2008 7:14:51 PM
rs670
Status: offline
Thanks for confirming my thoughts.... So, is there anything else to do other than replacing the ring?
       Post #: 8
RE: OS FS120S-E compression - 5/9/2008 7:37:31 PM
Flyer95
Status: online
What fuel have you been running in that engine? A castor/syntetic fuel is better for glow engines!
(in reply to rs670)
       Post #: 9
RE: OS FS120S-E compression - 5/9/2008 10:04:39 PM
Ken6PPC
Status: offline
quote:
ORIGINAL: rs670
Nothing I can think of. Strange that it would be worn out within two gallons.
AMA #853194
(in reply to rs670)
       Post #: 10
RE: OS FS120S-E compression - 5/9/2008 10:08:45 PM
Ken6PPC
Status: offline
You might want to look at this ad:
http://www.rcuniverse.com/market/item.cfm?itemId=392991
I don't have any connection with this seller, but it seems to be priced right.
Here is Tower's price:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCT32&P=Z
AMA #853194
       Post #: 11
RE: OS FS120S-E compression - 5/9/2008 10:36:30 PM
asmund
Status: offline
I had the exact same thing happen to a 30 fs that I just sold to a newcomer in our club. He suddenly had absolutely no compression even though I knew the engine was supposed to be like new, only just broken in. Problem was that I had told him to run his engine dry at the end of a flying session to avoid rust and somehow he had managed to run his engine so dry that it had absolutely no oil left in the sylinder. After I pulled the plug and squirted some fuel in it and cranked it up it was back to normal and running great.
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
