02ram4by4
IN, USA Status: offline
Hi I just purchased 2 tenergy 4200mah from allbattery. I also have there universal smart charger. I have a old school viper electric boat, that I put a 27 turn trinity motor,duratrax reverse esc, stock prop and no binding in the driveline. I put them on the charger they seem to charge fine and the green led came on. check the volts they were 8.40 on the first battery and 8.45 on the second. temp checked them while charging and they only got to 90 degrees. I went to run them for the first time seem to run good at first but the boat slowed just a little brought it back in to see if there was any thing on the prop nothing. Checked the temp of the motor and it was close to 250 degrees,they first battery pack was 150 degrees, then I let it cool and put the other battery in and the heat sink and the label melted off of one battery cell only and it was 260 degrees the rest were alot lower. hopefully someone will know if I did something or the batteries are the problem or the motor not really sure Dave
