STLPilot
NY, USA Status: offline
quote:
"Aircraft"??? Hmmm...maybe we do need a definition for model airplanes...this shows one good reason that even I can not discount. stl you win. dANG Simply stated, an unmanned aircraft is a device that is used, or is intended to be used, for flight in the air with no onboard pilot. These devices may be as simple as a remotely controlled model aircraft used for recreational purposes or as complex as surveillance aircraft flying over hostile areas in warfare. They may be controlled either manually or through an autopilot using a data link to connect the pilot to their aircraft. They may perform a variety of public services: Surveillance, collection of air samples to determine levels of pollution, or rescue and recovery missions in crisis situations. They range in size from wingspans of six inches to 246 feet; and can weigh from approximately four ounces to over 25,600 pounds. Like I said, brush up on your UAS policies, which are federal REGULATIONS, not advisories.
_____________________________
Here At The Wall
