RE: Lipo Pack for Transmitter ?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> RE: Lipo Pack for Transmitter ?
Page: <<   < prev  1 [2]
Login
RE: Lipo Pack for Transmitter ? - 5/12/2008 12:10:36 AM
AirWizard
Status: offline
quote:
ORIGINAL: goliathman
trust me if it exist it would be all over the net by now.
Well start searching the net....because I just tried it and there diffently is a hidden service menu.
_____________________________
David
____I'm having a Yak Attack_____
(in reply to goliathman)
       Post #: 26
RE: Lipo Pack for Transmitter ? - 5/12/2008 7:29:04 AM
gadix
Status: online
ok !
there you go.
i just want to add that i didnt made this procedure! i got from the internet in ASIA.
REMEBER!!! IF YOU DO A MISTAKE THERES NO TURNING BACK!!!
I SUGEST TO COPY YOUR SETUPS TO A DIFFERENT RADIO SO YOU WIL HAVE A BACKUP OF SORT!!!
Access to the 9303 is a closely guarded secret as the potential to cause chaos lurks within.
Make sure that THOTTLE HOLD is the rear right switch on top of set. ( IT IS THE SMALL "SLIDER" ON THE RT SIDE OF THE RADIO)
1 Pull Throttle Hold switch into the forward position.
2 Power the set on whilst ENT (Front Panel is pressed)
3 Rotate until Trim Step is highlighted.
4 Activate on Trim Step, rotate to AILE
5 Switch AILE D/R down, press roller activator, switch AILE D/R up, press roller activator.
6 Repeat sequences 4 times and on the 5th, access is granted to the EM.
From here, SW test allows you to test each switch and micro switch.
The next menu item is Hard. Con, on rotating the selector bar it becomes obvious what can be changed by “soft” selection. Where the highlighter does not move to indicates that this is a hard connection on the PCB, but in conjunction with the table this can be modified accordingly.
Next item is Stick Nut. Centralize all sticks and side trimmers, press CLR followed by STO. This then stores all the offsets for the sticks.
Next is Stick Ga., moving all sticks and side trimmers to max & min positions finalizes the stick calibration.
Moving the selector across to the right allows for setting front panel voltage, (Lithium voltage will display as 0.0V) and at what voltage the alarm will activate for low battery.
To exit this Engineering, rotate to EXIT then select Restart
< Message edited by gadix -- 5/13/2008 8:56:33 PM >
GADI,
ISRAEL
       Post #: 27
RE: Lipo Pack for Transmitter ? - 5/12/2008 11:47:31 PM
goliathman
Status: offline
quote:
ORIGINAL: AirWizard
WELL I TOLD YOU SO!!!!!!!!!!!!!!!!!!
ok !
there you go.
i just want to add that i didnt made this procedure! i got from a dear friend in UK that helps me all the on all JR products, especialy on radios....
so thank you dear UK friend....
SNIP
< Message edited by goliathman -- 5/12/2008 11:59:50 PM >
(in reply to AirWizard)
       Post #: 28
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.594RCU1
