Ehab
CA, USA Status: offline
quote:
ORIGINAL: av8rk a question about the plumbing on the fuel tanks.......... ok, it's obvious that the 1 liter tank will sit directly under the 2.5 liter main tank in the model....but according to the schematic i'm seeing is that the UAT will be fed by the main tank, and not the smaller tank.....i'm bringing this up because i've never seen a plumbing arrangement done this way before.....i'm not saying it won't work.....it's just that every fuel system i've seen or done on my own models is.......the fuel pump draws from the UAT, which draws from the 1 liter header tank, which draws from the main tank.....this way the fuel in the main tank is depleted first.....or, does it make any difference which tank is depleted first?..... any thoughts or comments out there from anyone? Richard I plumbed mine as you describe. It seems the proper way!!! It works either way thu.
_____________________________
Regards, E. " Smoking Sam"
