Geardaddys
Joined: 8/21/2006 From: Woodstock, MD, USA Status: offline
Fellas, Knocked over my Futaba 9C Super this morning (on carpet thank goodness) but evidently the 3 inch fall was to much for my "b" switch.. I don't really want to send it in because a: I don't want to pay for it! and b: I don't want to be out of the flying business for a few weeks.. Anyway, I think that tower sells these switches, but I am curious as to how difficult they are to replace.. Does the switch get soldered directly on the circuit board, or does it connect via wires? I'm comfortable doing wire soldering, but would be a bit nervous about trying to solder directly on the board.. I do have a friend who has done extensive electronic repairs, so he could probably help me out if it was a board thing. Anyway, if any of you have done this I'd really love some advice on how to do it, level of difficulty, etc.. Thanks a bunch.. John.. PS.. the switch still "works" if that matters, if you look in the hole that the switch sits in, there seems to be a little spring (not sure what that is for?) but if you move the spring, it actually still activates the high rate for that switch.. I guess I could use it like that, but Might not be able to get to it "in the heat of it" if I needed to..
