how to breaking in it a truggy
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> how to breaking in it a truggy
Page: [1]
Login
how to breaking in it a truggy - 5/8/2008 6:29:58 PM
dfaury
Status: offline
Hi, justy bought a trugggy on line.what is the best way to breaking in it
it seems that leaving the glow plug for a while makes the engine running smooth
so far i just used 1 tank running on idle
please let me know
       Post #: 1
RE: how to breaking in it a truggy - 5/8/2008 6:37:46 PM
slayerphonics
Status: offline
quote:
ORIGINAL: dfaury
please let me know
idle is old school way, do the heat cycle.
get it to 200 - 220 for about 5 mins with the truck on the ground moving.
shut it off,put it at BDC until ambient temp.
then repeat increasing the time spent at 200 - 220
do that for about 20 to 30 mins of run time and the motor should be broken in, i've had great sucess doing it this way.
there are alot of threads about it that go into more detail
_____________________________
There's a right way and wrong way to do everything and the wrong way is trying to make everybody else do it the right way
(in reply to dfaury)
       Post #: 2
RE: how to breaking in it a truggy - 5/8/2008 7:32:27 PM
dfaury
Status: offline
thanks, what do you mean by 200-220
do i have to remove the glow plug as well.seems running faster with the glow plug
(in reply to slayerphonics)
       Post #: 3
RE: how to breaking in it a truggy - 5/8/2008 7:37:38 PM
rebelracer246
Status: offline
what kinda truggy is it
http://www.youtube.com/watch?v=B6nJCigwtps
       Post #: 4
RE: how to breaking in it a truggy - 5/8/2008 7:42:03 PM
slayerphonics
Status: offline
no leave the glow plug in with the glow plug ignighter off, if its not running with it off its to rich,
You'll need a temp gun to help you heat cycle, or you can use the water method, drop a couple drops of water inside the head see how long it takes to boil off. if it starts frying right away your to hot
       Post #: 5
RE: how to breaking in it a truggy - 5/8/2008 7:45:06 PM
dfaury
Status: offline
1/8 Truggy,W/VX 21 Engine,AM Transmitter,9kg servo, battalian
(in reply to rebelracer246)
       Post #: 6
RE: how to breaking in it a truggy - 5/9/2008 5:46:14 AM
kweezinarts
Status: offline
200-220 degrees that is... like slayer said having a good temp gun helps alot. by glow plug i hope you mean your glow plug ignitor. use the instructions your truggy came with or search the forums for engine break-in there are lots of threads...
good luck and have fun...
NRusty 2.5 - TTR ST-1 w/ JPX.28 - Walkera Dragonfly #4
       Post #: 7
RE: how to breaking in it a truggy - 7/15/2008 11:28:52 PM
dfaury
Status: offline
hi, I am tunning my truggy, but everytime i apply the brake, the engine shut off.what is the best way to fix that problem
thanks to let me know
(in reply to kweezinarts)
       Post #: 8
RE: how to breaking in it a truggy - 7/16/2008 12:36:31 AM
windowlicker
Status: offline
you need to increase your idle by screwing in the idle screw a bit, screw it in until the idle does not change at all when you brake. you can take the air filter off (with the engine not running of course) to check that the carb is open by about 0.5-1mm at both idle and full brake.
Thing is, for it to be running with an idle set so low, your throttle linkage is most likely set to be opening the carb at idle, so when you raise the idle like I suggested above, you will need to back off your throttle trim on your transmitter or your engine will pull away without you accelerating
< Message edited by windowlicker -- 7/16/2008 12:39:48 AM >
Hellfire SS - GO .25 - DX3R - 5955TG - 5645MG - Speedtech Carbon
       Post #: 9
RE: how to breaking in it a truggy - 7/16/2008 5:53:48 AM
dfaury
Status: offline
thanks but sorry for my ignorance,
which idle screw are you talking about.?
(in reply to windowlicker)
       Post #: 10
RE: how to breaking in it a truggy - 7/16/2008 5:58:16 AM
rebelracer246
Status: offline
you will have a screw on an angle that is your idle and your low speed is on the slide part the main idle neddle and the low speed will effect it a little
       Post #: 11
RE: how to breaking in it a truggy - 7/16/2008 9:37:40 AM
windowlicker
Status: offline
yeah, the idle is the one coming out at about a 30 degree angle, usually just underneath the carb where the air filter fits on.
< Message edited by windowlicker -- 7/16/2008 9:38:02 AM >
       Post #: 12
RE: how to breaking in it a truggy - 7/16/2008 4:37:22 PM
dfaury
Status: offline
ok but what is the factory setting, since i have been screwing in and out , the idle.I am lost right now.
then when you have the factory setting, how much should i turn the idle.1/4 turn??
thanks for the advice
       Post #: 13
RE: how to breaking in it a truggy - 7/16/2008 4:53:37 PM
J24gordon
Status: offline
adjust it so it's idling steady but not stalling out or engaging the clutch
X2 CRT JPX .28 ,,,,,X1 CRT JPX .28
       Post #: 14
RE: how to breaking in it a truggy - 7/16/2008 4:55:58 PM
windowlicker
Status: offline
there is no factory setting for the idle needle. You have to take the air filter off so you can see down the carb (whilst the engine is NOT running obviously) screw in the idle needle so you have a gap of approximately 0.5 to 1mm when the carb is fully closed. you can then fine tune it when the engine is running and up to temperature.
(in reply to J24gordon)
