Socket head servo screws for 5955 TG
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Socket head servo screws for 5955 TG
Page: [1]
Login
Socket head servo screws for 5955 TG - 5/8/2008 7:30:20 PM
MR G
Status: offline
I have been looking on the internet for a socket head servo screw for the 5955TG servo horn.
I believe the screw is a 2.6 X 8 mm screw size. is this correct?
Do you know where I can find some of these screws?
I like to use loctite and the philips screws are just about impossible to remove after loctiting, the socket heads will be better.
MR G
_____________________________
Take-offs are optional...
Landings are mandatory!
       Post #: 1
RE: Socket head servo screws for 5955 TG - 5/8/2008 8:33:34 PM
A.T.
Status: offline
quote:
ORIGINAL: MR G I have been looking on the internet for a socket head servo screw for the 5955TG servo horn. I believe the screw is a 2.6 X 8 mm screw size. is this correct?
Do you know where I can find some of these screws? I like to use loctite and the philips screws are just about impossible to remove after loctiting, the socket heads will be better. Thanks,
MR G
Standard MG servo screw = 2.6mm x 8 mm = Hitec replacement part number #55802 which includes "Metal servo Screw Set (5 x short, 5 x long) " =
Hitec Screw Set for Metal Geared Servos
Standard Servo Screw s (Metal Gear Servos) 2.6mm x 6 mm & 8 mm to fit
HS-225MG, HS-525MG, HS-625MG, HS-645MG, HS-705MG, HS-925MG, HS-945MG,
HS-5245MG, HS5625MG, HS-5645MG, HS-5745MG, HS-5925MG, HS-5945MG, HS-
5955TG, HS-5995TG, HS-5996TG, HS-5997TG, HS-5998TG.
The Five 2.2 x 5 mm Phillips head screws fit the HS-65MG, HS-81MG, HS-85MG,
NB: Never use loctite, in need if star washer is lost, used sparingly and ensure none remains in contact with plastic parts. Liquid Thread Lock
Socket head replacement screws are available from Micro Fasteners
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
< Message edited by A.T. -- 5/8/2008 8:37:06 PM >
(in reply to MR G)
       Post #: 2
RE: Socket head servo screws for 5955 TG - 5/8/2008 8:51:04 PM
MetallicaJunkie
Status: offline
these have socket heads http://www.airwildpilotshop.com/MoreInfo-1.asp?title=product&id=491 the work great
Revver Bro #217
(in reply to A.T.)
       Post #: 3
RE: Socket head servo screws for 5955 TG - 5/8/2008 9:31:00 PM
MR G
Status: offline
Metallica,
Thanks, I ordered a buch!!
MR G
(in reply to MetallicaJunkie)
       Post #: 4
RE: Socket head servo screws for 5955 TG - 5/9/2008 4:52:38 AM
MetallicaJunkie
Status: offline
no prob
Revver Bro #217
(in reply to MR G)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.250RCU1
