MJD
ON, CANADA Status: offline
quote:
ORIGINAL: Jim Thomerson When you fill a balloon tank, you get all the air out, so the pickup is in fuel all the time. Yep. The way you do that easily and reliably, maaaarius (is that the right number of "a's"?), is to get yourself a large syringe, 30ml - 60ml or so. You want one that has at least double your intended fuel capacity. Rig the syringe however you wish to, so that it has a fuel tubing nipple on the end of a section of filler line made from flexible tubing long enough to draw fuel from your can. Depress the plunger all the way, then draw in as much fuel as you want to be in the tank plus a few ml more, e.g. 5ml extra. Now, disconnect the fuel line from the engine and connect this to the filler line on the syringe. You must now hold the syringe vertically, filler line down, and pull the plunger back farther - it will now suck out any air from within the tank. This air will bubble up through the fuel in the syringe. and collect at the top of the column. When you have drawn out all the air, depress the plunger to discharge the fuel, which is now at the bottom of the syringe with the air on top, into the bladder. BUT, be careful you do not inject any air into the bladder after the fuel - this is where the extra 5ml of fuel comes in. Discharge the amount wanted in the tank, and stop when only the 5ml of fuel is remaining. Done! Connect the fuel line to the engine again, and take care to keep the nose up a bit from now on as fuel will easily gravity siphon into the engine. It takes much more time to explain it than to do it. It is extremely simple when you understand what you are trying to accomplish - no air in the system - and how. Make darn sure you are not creating any pressure in the bladder! Know the relaxed capacity of the bladder beforehand. This is a key point of their use - you must fill them only to capacity or you will have some misery either due to bladder pressure or damage to the bladder itself. This BTW is how you fill Jett and Tettra bubbleless tanks as typically used in pylon racers, and by those that have seen the light with respect to bladder tanks and their miraculous properties. Oddly, many people never try them, yet they are so simple, and so amazingly effective at eliminating fuel system troubles. They are, IMHO, well worth the money and more so in terms of peace of mind, and I have decided I will from this point forward use only bladder tanks of some sort in all my glow aircraft, no matter the aircraft type and purpose. Hope this is of some help. MJD (EDIT) p.s. the fuel will swell the rubber plunger in the syringe, so I keep them empty at all times when not using them, and usually get along okay. If you remove the plunger and let it dry out it will reduce in size again, eventually. A filler I own made by Jett, uses a metal plunger with o-ring seals that are compatible with fuel, so it doesn't have this problem.
< Message edited by MJD -- 5/8/2008 11:00:51 PM >
