Battle field props
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> Battle field props
Page: [1]
Login
Battle field props - 5/8/2008 9:24:40 PM
edoubleaz
Status: online
Gang,
Just finished a weekend project I thought you'd enjoy. I took all the leftover parts from the T34 projects on my shelf and cobbled together a burned out T34-85. I have put small battery powered flickering lights inside to act as flames for our night battle. I have plans of rigging a smoker inside for day time events. Total project cost, $10 for the lights from Michaels.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
check out www.desertarmor.com for all our work.
       Post #: 1
RE: Battle field props - 5/8/2008 9:55:55 PM
tailend charlie
Status: online
Nice!!! We can't wait for the night battle.
(in reply to edoubleaz)
       Post #: 2
RE: Battle field props - 5/8/2008 10:00:35 PM
pattoncommander
Status: online
Looks good, but if it's burned, all the suspension should be collapsed. Move all the swing arms up as far as they willl go and make the track as loose as possible and droop them over the road wheels. The fuel drum would be totally gone as the explosion would leave nothing there, except ,maybe a sliver of an end piece on the bracket. If you want to make it really reslistic, take off the rubber tires and dremmel the ridges down..leave the residue on the wheels (glue it secure) to represent burned rubber. Here's the best smoker to use. Batteries at Radio shack are expensive, but the results of that large volume smoker are worth it.
Click for fullsize
Click for fullsize
       Post #: 3
RE: Battle field props - 5/8/2008 10:32:10 PM
blitzkrieg65
Status: offline
quote:
ORIGINAL: edoubleaz
Gang,
Nice work Edoubleaz, I still have to rig up a light for my KT, the Pershing is getting a few upgrades and other then that I am ready to go!
The Blitz
< Message edited by blitzkrieg65 -- 5/8/2008 10:33:21 PM >
       Post #: 4
RE: Battle field props - 5/8/2008 10:37:21 PM
blitzkrieg65
Status: offline
quote:
ORIGINAL: pattoncommander
Bill,
I might just break down and try one of those smokers! Evey once in a while I will crack open a hL one and try a dfferent mod, it fails back to the drawing board, think of something else,, it fails, back to the drawing board, to do it all over again! I guess that is half the fun of it from me!
da Blitz
(in reply to pattoncommander)
       Post #: 5
RE: Battle field props - 5/8/2008 11:11:53 PM
pattoncommander
Status: online
I tried using the HL smokers but all they did was eat batteries sound too loud and give a mere hint of smoke. This is not the big smoker I got....they have a bigger one but I settled for a small-medium size. At any rate, it does pump out the smoke and looks realistic. If I could only get a way to color the smoke black , it would be better. These are available at any hobby shop dealing with RR trains. Not cheap, but as I wrote, worth it for the results obtained. This would be a great deal to set up in a battle system to set off when the final "kill" shot is received.
(in reply to blitzkrieg65)
       Post #: 6
RE: Battle field props - 5/9/2008 9:49:01 AM
edoubleaz
Status: online
A note on this project, it is meant to be left outside and exposed to the elements. If it were a 1/35 scale kit I would have torn up all kinds of things and made it look spot on. This kit was completed in two 1 hour sittings. I have spent more time on my dragons' teeth and pill boxes. The T34 was a gimmick at best and I used all the good details on my two working kits.
       Post #: 7
RE: Battle field props - 5/9/2008 3:58:53 PM
Panther F
Status: offline
What a great project for those static kits that do not get R/C'd!
Tamiya 38-cm Sturmmorser, M4 Sherman, M26A1 Pershing, M4A1E8 Sherman, TI, Panther, Jagdpanther, KT, WSN/Tamiya T34 & SU-85
       Post #: 8
RE: Battle field props - 5/9/2008 4:41:25 PM
SCAT PATTON
Status: offline
Hey,
The Me-262 & Mec Worrior arent to scale!!
Cool post!
(in reply to Panther F)
       Post #: 9
RE: Battle field props - 5/9/2008 6:32:54 PM
Jeff489
Status: offline
Umm, last I checked, the T34-85 was powered by a 500hp V-12 which ran on deisel. I'm not aware it was explosive. I'm guessing realistic damage would depict a ruptured fuel tank (from expanding gasses inside) and then after effects of burned off fuel, which pretty much looks like the model here...
For the minimum effort and expense, the tank looks great!
Jeff O.
(in reply to SCAT PATTON)
       Post #: 10
RE: Battle field props - 5/9/2008 6:48:02 PM
Panther F
Status: offline
quote:
ORIGINAL: Jeff489
Shhhhh! He doesn't know that diesels work on the principle of compression, not detonation.
(in reply to Jeff489)
       Post #: 11
RE: Battle field props - 5/9/2008 6:54:16 PM
123Splat
Status: offline
Ever notice that when a thread about destroyed armor comes up, and I admit that I could be wrong here, but from my limited experience,
THEY ALWAYS CHOOSE A T-34 TO BLOW UP?
Not that I have any aversion to blowing up a Russian tank, mind you. But,,,
It's not the takeoff or the flying, it's the landing and repairing, so I can takeoff and fly again...
       Post #: 12
RE: Battle field props - 5/9/2008 10:21:59 PM
pattoncommander
Status: online
ssshhhh not too loud, but I have seen and looked over a number of T-34/85s, mostly from the 3d NKA Inf div that were taken out by
F-80 and F-86 using rockets and cal 50 AP rounds. They were all crispy critters...diesel does burn, and hotter than gasoline, just harder to get it going. Fuel drums on those tanks were non existant, they were obviously only half or less full and subsequently burst and spread the fuel over the rest of the tank. A full fuel tank will not burn unless it is punctured. One that is half full will, due to the space inside for fumes and pressure to built up.
Still, a nice model edoublease, and it will be nice attraction with a smoker and the lights you have in it. What kind of lights do you use? Wondering if I could wire them into my smoker batteries. It would look great at night. Post some night photos.
       Post #: 13
RE: Battle field props - 5/10/2008 7:29:09 AM
caragan1970
Status: offline
Hi Guys,
Nice battlefield props... I saw a way to make artificial fire
when I was in Dubai Airport, they have this artificical fire lamps.
Its uses a pieces of white cloth cut into a fire shapes and the
top edge portions was coloured yellow orange. On the lower part
there was an air blower the push the cloth upwards. Orange & yellow
LEDs below the light up the lower part of the flame.
Very good fire illussion from a distance.
Now to find a way to put it inside a tank Don't forget the smoker
for add effects.
Patrick C.
Click for fullsize
Click for fullsize
1/16 HL Tiger 1, HL M26 Pershing, WSN T34/85, 1/24 VStank Pro M1A2 Airsoft, M1A2 Sparkling, Type 90, Leo2 A5, 1/12 Hailang M
       Post #: 14
RE: Battle field props - 5/10/2008 11:08:58 PM
