OS 18tm into NTC3
Tower Hobbies
Logged in as Guest
  Printable Version
CEN Racing CT4S - RTR
Seller:  solidgold5
Details:   $200.00   |  7/15/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> OS 18tm into NTC3
Page: [1]
Login
OS 18tm into NTC3 - 5/8/2008 11:19:25 PM
ajb1205
Status: offline
I have a pretty much brand new OS 18tm in my Revo but would really like to upgrade to a more powerful engine. I also have a FT NTC3 without a motor. I realize the OS 18tm will bolt right in but the crank shaft will have to be changed. My question is what crank would I need to get (would the crank from the tz work?) and is this even worth while since I can get a brand new OS 18 crv for $110 (but I REALLY want more power in my Revo)?
Thanks guys.
_____________________________
Revo w/O.S. 18tm, E-Revo
NTC3, Brushless RC18T, Mini-T
       Post #: 1
RE: OS 18tm into NTC3 - 5/8/2008 11:27:39 PM
ferrarimk13
Status: offline
the tm will be fine, but is it a short shaft? if it is just add a clutch nut and youre set, no change of shaft.
press Alt+F4 for a good time.
(in reply to ajb1205)
       Post #: 2
RE: OS 18tm into NTC3 - 5/9/2008 12:32:12 AM
CBM Racing
Status: offline
I run a 18tm (modded)in an rs4 with a traxxas clutch and a hpi clutchbell. The only issue is the car basically falls apart under any stress, but the tc3 should be golden.
MMmm..Piepants..
(in reply to ferrarimk13)
       Post #: 3
RE: OS 18tm into NTC3 - 5/9/2008 5:04:39 PM
Bluebrew
Status: offline
Doesn't the OS 18TM have Traxxas specific mounting lugs?
Sure, electrics' go, but nitros' RUN!
(in reply to CBM Racing)
       Post #: 4
RE: OS 18tm into NTC3 - 5/9/2008 9:54:20 PM
ferrarimk13
Status: offline
not sure, but if anything he can get cheap hpi mounts for like $8
(in reply to Bluebrew)
       Post #: 5
RE: OS 18tm into NTC3 - 5/10/2008 3:21:40 AM
CBM Racing
Status: offline
Same mounting hole pattern as any small block, but traxxass specific threads and size flywheel nut. Like I say, just use trx flywheel, nut, clutch shoes and a hpi clutchbell. You may need to cut the clutchbell down to fit properly, but no biggie. This engine rocks in an onroad car, gobs of torque so you can gear pretty high, and pretty high rpms. Tc3 should handle power just fine and give good all around performance. Not as good as a tz, but nothing to sneeze at for sure . Good luck and have fun!
MMmm..Piepants..
       Post #: 6
RE: OS 18tm into NTC3 - 5/12/2008 3:44:54 PM
ajb1205
Status: offline
Thanks for the info guys.
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.406RCU1
