jaymen
CA, USA Status: online
NiMH cells are only 1.1 volts each. If for example you had a 4 cell NiCad pack, 1.2 volts per cell, it would be 4.8 volts. If you replaced the 4 cells with NiMH type cells, you would only have 4.4 volts. This would result in less "punch" due to the reduced voltage. The answer is to use 5 NiMH cells, that would give you 5.5 volts. For the same physical size and weight, you can almost double the capacity when replacing NiCads with NiMH cells, but you have to add extra cells to make up for the voltage differance. NiMH cells supposedly have no memory, but in practice, they do benefit if you drain them down and then fully charge them once in a while(cycling). NiMH batteries perform the best and deliver the fullest capacity only when used hot off the charger. If you let them sit for a couple days, re-peak them on the charger for best performance. NiMH battaries do not have the life of NiCads, this is because when you have more capacity in the same size package, the plates and electrolye are thinner and deteriorate faster. Therein lies the trade-off of price, size, and performance. I used to use a 6 cell NiCad, 350 mAh, 7.2 volt pack for my GWS Tiger Moth park flyer. I have a 7 cell NiMH pack, 800 mAh 7.7 volt pack in there now which almost doubles my flight times.
_____________________________
Did you charge the transitory remitter batteries ?
