Replace leaking Ninja Front Bearing with Ninja bearing or other brand?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> Replace leaking Ninja Front Bearing with Ninja bearing or other brand?
Page: [1]
Login
Replace leaking Ninja Front Bearing with Ninja bearing ... - 5/9/2008 2:40:14 AM
UG0TB4NN3D
Status: offline
I've got a leaking front bearing in my ninja .28, which I've heard I shouldn't worry about, but it makes me uneasy that the bearing is leaking, and I'd like to replace it. $30 bearing or $300 engine, I'd like to go the cheaper route.
What are the best bearings to buy to replace front bearings? The measurements are 7x9x6mm.
Thanks.
_____________________________
<s>Jammin'''''''' X1 CRT Pro, BCE PJX Chassis + Small Spur mod, Ninja .28 Powered, Spektrum DX 2.0M</s> - <b&
       Post #: 1
RE: Replace leaking Ninja Front Bearing with Ninja bear... - 5/9/2008 4:05:53 AM
hrdcoreglf
Status: offline
If you get in touch with these guys and tell them what sizes you need they can hook you up with different choices at different prices. http://www.bocabearings.com/main1.aspx?p=about
Wisdom is only as good as the person you give it to.
(in reply to UG0TB4NN3D)
       Post #: 2
RE: Replace leaking Ninja Front Bearing with Ninja bear... - 5/9/2008 5:11:26 AM
rageworks
Status: offline
Amain has the TKO ceramic 7x19x6 front engine bearing for $14.99
Good bearing, good deal.
(in reply to hrdcoreglf)
       Post #: 3
RE: Replace leaking Ninja Front Bearing with Ninja bea... - 5/9/2008 5:12:58 AM
Dale Gribble
Status: offline
You will probably need one of those bearing presses too.. Some guys can do it with a combo of heat/cold. Why not call Ninja and see if they will replace the engine? Sounds like a MFG defect.
MFRCX SvSS XFctr GST77 HPR7PR XT2 X1CR-FT X1-CRTPR GigDFx2x28 MLST2 MQS PTMMT Maxx Zilla Jgg2 NTC3 4TEC3.3
5B SS
(in reply to rageworks)
       Post #: 4
RE: Replace leaking Ninja Front Bearing with Ninja bea... - 5/9/2008 5:32:44 AM
pur3evil
Status: offline
Bearings are easy to replace. I use the method RB Concepts recommends.
Ditto on the TKO ceramics. I have one in both my RB C6BB and Sportwerks .26v2.
-Howard
< Message edited by pur3evil -- 5/9/2008 5:33:16 AM >
(in reply to Dale Gribble)
       Post #: 5
RE: Replace leaking Ninja Front Bearing with Ninja bea... - 5/9/2008 6:19:16 AM
UG0TB4NN3D
Status: offline
I contacted Ninja and thy said that because GRP dropped them, I'd have to contact GRP directly and then see what they'd do.
But I'd have to ship it to Italy.
(in reply to pur3evil)
       Post #: 6
RE: Replace leaking Ninja Front Bearing with Ninja bea... - 5/9/2008 8:08:51 AM
supertib
Status: online
Send the motor to AB for mods and a new bearing !
Warning !!!! I have an opinion and I am not afraid to use it !
       Post #: 7
RE: Replace leaking Ninja Front Bearing with Ninja bea... - 5/9/2008 2:07:39 PM
Dale Gribble
Status: offline
Ah, better to do it yourself then I suppose.
5B SS
       Post #: 8
RE: Replace leaking Ninja Front Bearing with Ninja bea... - 5/9/2008 5:04:57 PM
RevToTheRedline
Status: offline
I found that my TKO ceramic front bearing started leaking as fast as the stock OS one I replaced. I'd say go with Boca.
Mugen Seiki MBX5R : RB C6BBT II L2G w/ RB 2045 : Futaba 3PKS 2.4Ghz Fasst : Ace 1015/1313 : Lots of weight reduction mods
       Post #: 9
RE: Replace leaking Ninja Front Bearing with Ninja bea... - 5/9/2008 5:40:31 PM
Baedarlboo
Status: offline
Does everyone here know that small amounts of leakage is normal from the front bearing, as they are not completely sealed....
Running the motor rich also makes it seem worse. Your motor is not a completely sealed system, it's normal to have small amounts of oil.
(in reply to RevToTheRedline)
       Post #: 10
RE: Replace leaking Ninja Front Bearing with Ninja bea... - 5/9/2008 6:10:45 PM
The Winner
Status: offline
i have also a tko ceramic in my lrp z.28r!! when i bought it ,it has some play! also i remove the one seal! i have put it in my engine but i dont run it yet! is good bearing??also i replace the rear with boca lighting ceramic! i make good choises?
(in reply to Baedarlboo)
       Post #: 11
RE: Replace leaking Ninja Front Bearing with Ninja bea... - 5/10/2008 4:07:08 AM
UG0TB4NN3D
Status: offline
It wasn't just small amounts of oil. :| When I blew in the line, bubbles came out, which meant that there was also an air leak.
(in reply to The Winner)
       Post #: 13
RE: Replace leaking Ninja Front Bearing with Ninja bea... - 5/10/2008 4:22:18 PM
supertib
Status: online
quote:
ORIGINAL: UG0TB4NN3D
No thats pretty normal and doesn't mean there is necessarily an airleak.... is the motor suffering from air leak symptoms ?
       Post #: 14
RE: Replace leaking Ninja Front Bearing with Ninja bea... - 5/10/2008 7:43:28 PM
UG0TB4NN3D
Status: offline
Yeah, during a normal run, and it's tuned pretty rich, but it was running around 350 when I temped it, so I haven't run it since then.
(in reply to supertib)
       Post #: 15
RE: Replace leaking Ninja Front Bearing with Ninja bea... - 5/10/2008 10:02:36 PM
supertib
Status: online
well don't feel too bad my OS 28 is leaking from the front bearing something fierce...Just pissing fuel all over the truck and motor..... I leave the motor sit overnight and there is a huge puddle under the truck where oil has seeped out the motor and onto the table.... Motor still runs really good, only symptom is it wants to slightly hang the RPM up after a high speed pass.. other then that its running pretty much flawlessly..I should have some video of it today..
       Post #: 16
