cleaning the exhust valve
Tower Hobbies
Logged in as Guest
  Printable Version
TurboHeader Muffler
Seller:  RC Specialties
Details:   $69.95   |  5/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> cleaning the exhust valve
Page: [1]
Login
cleaning the exhust valve - 5/9/2008 3:01:31 AM
borna
Status: offline
what's the best way to clean the exhust valve on a 4 cycle engine without taking the valve out?
This is for an old OS FS 60 4 cycle engine, which I think the valve is leaking due to high carbon deposit.
Borna
       Post #: 1
RE: cleaning the exhust valve - 5/9/2008 4:54:19 AM
Gizmo-RCU
Status: offline
I had an old Saito 45 that required this once a year. Remove the exaust pipe so you can look into the port and then remove the valve cover. Make sure the valve is closed so that the carbon will not enter the cylinder.
Take a wooden tooth pick and loosen the carbon or use a paper clip end if it's stubborn. gently start pushing on the carbon and breaking it loose, don't gouge up the chamber while doing this. You can rotate the valve by pushing slightly down and turning with your finger. Use air to blow the material out and carefully inspect and remove until the job is done. This is very easy to do and there is nothing to damage if you are careful. Set the valves when you have the carbon out, put back together and go fly.
_____________________________
Gizmo
(in reply to borna)
       Post #: 2
RE: cleaning the exhust valve - 5/9/2008 6:29:29 PM
scratchonly
Status: offline
I read in a Clarence Lee column that you can dribble fuel injector cleaner down the carb with the engine running. Never tried this.
Real planes have two wings and round engines
(in reply to Gizmo-RCU)
       Post #: 3
RE: cleaning the exhust valve - 5/9/2008 7:10:36 PM
borna
Status: offline
I have the head out and there are some carbon build up on the valve sit and valve face therefore causing small air leak. So is there any solution that I can soak it in to desolve those gunk? As suggested maybe fuel injector cleaner?
Borna
(in reply to scratchonly)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.233RCU1
