Help installing wheel pants on EF Extra 260
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> Help installing wheel pants on EF Extra 260
Page: [1]
Login
Help installing wheel pants on EF Extra 260 - 5/9/2008 12:27:21 PM
medcinmn
Status: offline
I'm building my EF Extra 260 480 and when I installed the wheel pants, the screw that holds them on begins to hit the wheel when just screwed in about 2/3 of the way. If I screwed it in all the way it would go into the wheel.
I put it together exactly as described in the manual, and am pretty mechanically inclined. Other than some type of spacer, it doesn't appear this will go together properly if put together the way the manual states.
Any thoughts or help is appreciated.
Thx,
Aaron
       Post #: 1
RE: Help installing wheel pants on EF Extra 260 - 5/10/2008 12:07:27 AM
medcinmn
Status: offline
I'm a dummy who apparently cannot read. I read and re-read the instructions and skipped over the part where it tells exactly what to do to avoid what happened!
Other than that, the plane's about finished. I'm going with the Scorpion 3008-32.
(in reply to medcinmn)
       Post #: 2
RE: Help installing wheel pants on EF Extra 260 - 5/10/2008 2:36:35 AM
rcfreakazoid
Status: offline
quote:
ORIGINAL: medcinmn
just out of curiousity what part was skipped to resolve the issue?
_____________________________
Later.
       Post #: 3
RE: Help installing wheel pants on EF Extra 260 - 5/10/2008 2:37:51 PM
medcinmn
Status: offline
There is a regular 4-40 nut (not lock-nut) that goes on after the second lock nut. Basically, you put the 4-40 hex head bolt through wheel, then a washer and lock-nut, put the assembly through the landing gear, secure it with the second washer and lock-nut then put the 4-40 regular nut as a spacer.
(in reply to rcfreakazoid)
       Post #: 4
RE: Help installing wheel pants on EF Extra 260 - 5/10/2008 4:51:21 PM
50mph
Status: offline
I have had my EF 260 since last year, Very good and fun plane to fly. The only problem I had was I used a 10BL for the motor. The 10BL is just a pinch larger than the 480. I I had to make adjustments to the cowl and grind the opening a little. Nothing really hard. I will ay the EF 10BL really brought the plane to life and had enough poweer to do anything.
       Post #: 5
RE: Help installing wheel pants on EF Extra 260 - 5/11/2008 2:45:06 AM
medcinmn
Status: offline
Thx for the info, I'm leaning towards the Scorpion 3008-32.
(in reply to 50mph)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.348RCU1
