AeroFly Professional Deluxe
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> AeroFly Professional Deluxe
Page: [1]
Login
AeroFly Professional Deluxe - 5/9/2008 1:13:59 PM
kwarner
Status: offline
There is a wide range of turbine powered helicopters as well as a couple turboprop machines as well in AeroFly Professional Deluxe. Is there a way to source / import jet turbine/ turboshaft / turboprop ".wav" files for use with the models?
The reciprocating engine sound that is used for the turbine models does not compliment the high quality of the rest of the simulation.
Konrad
       Post #: 1
RE: AeroFly Professional Deluxe - 5/13/2008 1:38:00 AM
rajul
Status: online
You can exchange the sound files of any particular model to that of another which you prefer. Go into the AFPD aircraft directory C:\Program Files\IPACS\AeroFly Professional Deluxe\aircraft Here you will find all the aircraft folders. The .tmd file is where all of the sound files are called.
Here's how you do it:
1. Open the .tmd file in the particular aircraft folder with notepad and use the "Find" option (under the "Edit" tab) to find the word "sound". There it gives you the file names that are used. In this case it's like "Extra 330-xxxx" for planes, and "gheli1" for helicopters (skip the "blade1" sound file)
2. Look in your Sound folder C:\Program Files\IPACS\AeroFly Professional Deluxe\sound for the names of alternative sound files to use.
3. Replace the "Extra 330-xxxx" information (there are typically three entries for planes and one entry for helicopters) with the name of a sound file you want in the sound folder.
4. Go to "File" and click "Save" and you're all set.
< Message edited by rajul -- 5/13/2008 1:39:21 AM >
_____________________________
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
(in reply to kwarner)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.266RCU1
