LST2 Transmisson problem, help!!
Tower Hobbies
Logged in as Guest
  Printable Version
CEN Racing Genesis Monster Truck - RTR - RTR
Seller:  solidgold5
Details:   $250.00   |  7/15/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Losi Monster Trucks >> LST2 Transmisson problem, help!!
Page: [1]
Login
LST2 Transmisson problem, help!! - 5/9/2008 1:34:06 PM
Jamezy
Status: offline
im having this problem after 2 days of running brand new lst2
http://www.youtube.com/watch?v=AJDaliE_khI
Please can someone tell me what part i need to buy in order to fix this or the part number.
Thanks in advance
This is frustrating
       Post #: 1
RE: LST2 Transmisson problem, help!! - 5/9/2008 2:58:31 PM
2DMaxLST!!
Status: offline
You can clean and lube the OWB in the two speed assembly to fix it.
_____________________________
I always hand out free Air Guitars in my pit area.
(in reply to Jamezy)
       Post #: 2
RE: LST2 Transmisson problem, help!! - 5/9/2008 3:24:07 PM
Sugafree
Status: offline
Yep I agree with 2D......Clean the OWB first......
You Should Also,
Check your EPA on the Reverse Servo so it's not Slipping in-between Gears......
Turn the Radio on, then press the Scroll button till you See EPA Then Press channel till you see AUX then turn it up (Increase) the EPA till the Servos moving far enough to Hold it in Gear.....
(in reply to 2DMaxLST!!)
       Post #: 3
RE: LST2 Transmisson problem, help!! - 5/9/2008 6:19:16 PM
str8jailbird
Status: offline
Looks to be the OWB, clean it and reoil like they said. If it isn't the OWB it would be the drive pin in the tranny on the selector shaft.
(in reply to Sugafree)
       Post #: 4
RE: LST2 Transmisson problem, help!! - 5/10/2008 3:35:10 AM
CBM Racing
Status: offline
What is everyones suggested way of cleaning the owb? I always here (see )people say to clean it, but no instructions on how, so how about it guys?
MMmm..Piepants..
(in reply to str8jailbird)
       Post #: 5
RE: LST2 Transmisson problem, help!! - 5/10/2008 6:55:49 AM
Jamezy
Status: offline
yeah how do i clean it?
Good explanation will be good
(in reply to CBM Racing)
       Post #: 6
RE: LST2 Transmisson problem, help!! - 5/12/2008 4:32:15 PM
BioRev
Status: offline
Take off the gear cover, remove the first gear and remember the order the nut and washers where in. On the back of the first gear remove the 3 screws holding the OWB in. You can either clean it with a rag and reoil it or use gun oil like i do and soak it for the night then let it dry and reoil. Remember what way the OWB came out and make shure you put it back in the correct way.
< Message edited by BioRev -- 5/12/2008 4:35:18 PM >
       Post #: 7
RE: LST2 Transmisson problem, help!! - 5/12/2008 10:17:08 PM
str8jailbird
Status: offline
To really clean it take apart your 2- speed and soak it in a degreaseing solvent. Let it dry and reoil and reinstall your 2-speed.
(in reply to BioRev)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.406RCU1
