Sherman gear reduction
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> Sherman gear reduction
Page: [1]
Login
Sherman gear reduction - 5/9/2008 9:43:25 PM
tailend charlie
Status: online
I was installing the 400 long cans on my Tamiya Sherman, when the slider on top of the trans got my curiosity going . I took it a part and removed the shims on the shaft. Walla I have gear reduction. The slider moves the gear from normal to reduction. Why don't the others have the same set up? At least my Panther, Tiger and KT don't have it. They are all the newer black cased trans. Kinda cool feature having a choice of having a gear change at the flick of a lever.
       Post #: 1
RE: Sherman gear reduction - 5/9/2008 11:26:21 PM
Jeff489
Status: offline
Sounds like a good reason to own a Sherman to me!
_____________________________
Jeff O.
(in reply to tailend charlie)
       Post #: 2
RE: Sherman gear reduction - 5/10/2008 4:57:57 AM
blitzkrieg65
Status: offline
quote:
ORIGINAL: tailend charlie
Tailend can you take a picture of the part you are removing and what the gearbox looks like?
The Blitz
       Post #: 3
RE: Sherman gear reduction - 5/10/2008 5:57:07 AM
tailend charlie
Status: online
The trans look the same except the Sherman looks to have a few more gears and the slider. Here is the picture of the trans top with lever. Also the sleeves I removed of the shaft. They were stopping the gear from moving with the lever. There is a difference in running when you switch the gears.
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to blitzkrieg65)
       Post #: 4
RE: Sherman gear reduction - 5/10/2008 12:52:18 PM
TXtanker
Status: offline
I remember some years back this was done but the gears started to self destruct for some reason.... do a search on Armornuts site and you may find the referance. Id hate to see your boxes get fried!
So many tanks so little time................
       Post #: 5
RE: Sherman gear reduction - 5/10/2008 5:50:40 PM
tailend charlie
Status: online
Thanks for the heads up. I found a discussion on that board dated Jan. '05. It was between Nick, Willy and another guy discussing gear reduction on the Sherman. He mentions a plastic gear slipping so he screwed it to the metal gear next to it. I looked at my gear box and with out taking it a part I don't see a plastic gear that could cause slippage. All the gears I see clustered together are metal. They may have changed them. I guess I will take it apart and find out for sure. I really like the slower speed and torque you get with this FREE reduction.
(in reply to TXtanker)
       Post #: 6
RE: Sherman gear reduction - 5/10/2008 7:21:05 PM
Panther F
Status: offline
I tested this set up. The gear mesh is horrible and probably will tear things up eventually so I put the gears back in the original arrangement. I wouldn't recommend it plus, you should really run some Graupner SPEED 400 6v motors over the 400 long cans with a stock gearbox. Better battery life.
Tamiya 38-cm Sturmmorser, M4 Sherman, M26A1 Pershing, M4A1E8 Sherman, TI, Panther, Jagdpanther, KT, WSN/Tamiya T34 & SU-85
       Post #: 7
RE: Sherman gear reduction - 5/10/2008 11:39:49 PM
tailend charlie
Status: online
I checked the meshing and there seems to be equal clearence in both positions. No excessive noise either. I run the 400 long can set up with dual 4200mah batteries. The tanks seem to have a good run time and almost unstoppable. I heard that the 400 6v is harder on the DMU and the long can 12v were better. I have already installed the long cans in all my tanks except the KT which has the new impact gear reduction trans and older Zigi 400 motors. I guess I could invest in a pair of Graupner SPEED 400 6v motors and test the difference. Thanks for the info.
(in reply to Panther F)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.766RCU1
