hbk2 main blade replacement
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Esky Helicopters >> hbk2 main blade replacement
Page: [1]
Login
hbk2 main blade replacement - 5/10/2008 2:50:00 AM
dafly
Status: offline
Do I have to use e-sky blades on my hbk2? My LHS doesn't carry e-sky and I was wondering if I went and found another brand of blades that were close to the same size if I could use them?
       Post #: 1
RE: hbk2 main blade replacement - 5/10/2008 2:59:36 AM
noobflyer01
Status: offline
as long as they fit yes. the king blades are 275mm stock. its really hard to find these blades at your local hobby store. i suggest you stay with that size for this heli. stock up those blades. jaghobbies have bundles you can buy to save a few bucks. they are reliable and reasonbly quick shippment. and they're in the USA. . ka-planes also carrys them but dont bundle them like jaghobbies but they ship very quick. usually 3 days max.
_____________________________
EF mash rescue Co-ax, HBK2, HBFP, Belt CP, Blackhawk 450, EXI 450, trex 450 SA, mars 480, mini titan e325
(in reply to dafly)
       Post #: 2
RE: hbk2 main blade replacement - 5/10/2008 3:04:58 AM
brac1960
Status: offline
I believe the E-flight blade will fit. I bought some E-flight 325 blades for my belt cp. The root end was exactly the same as the stock E-sky blades.
(in reply to noobflyer01)
       Post #: 3
RE: hbk2 main blade replacement - 5/10/2008 3:08:18 AM
jeremycann08
Status: offline
cp2 are bigger then hbk 2
(in reply to brac1960)
       Post #: 4
RE: hbk2 main blade replacement - 5/10/2008 3:08:55 AM
noobflyer01
Status: offline
brac he has the king2. the king2 will defintely not fly well with the 325's on it. i think the other eflite blade for the eflite cp is 255mm. its a little to short with the 255's or a little to long with 315's or 325's.
       Post #: 5
RE: hbk2 main blade replacement - 5/10/2008 3:15:52 AM
brac1960
Status: offline
I realize the 325's would be too big, thought maybe E-flight had a 285 blade??? I think that you are correct. I think the lhs did only have like 255's or something.
       Post #: 6
RE: hbk2 main blade replacement - 5/10/2008 3:40:32 AM
homeunt
Status: offline
anything aroudn 265~300mm is all right. Just be aware, heavier the blades, hotter your batt, esc and motor gets.
This hobby is funny, if I got cash, I got no experience.
If i got experience, I see a giant hole on my wallet.
       Post #: 7
RE: hbk2 main blade replacement - 5/10/2008 5:42:32 AM
KCinNC
Status: offline
try ebay...i buy alot of esky stuff from member cwtco......got 5 pairs of blades for around $25 shipped. these are NOT original esky king2 blades, to me they are better !!!
(in reply to homeunt)
       Post #: 8
RE: hbk2 main blade replacement - 5/10/2008 2:37:36 PM
selime
Status: offline
DAfly .. get a set of these blades for your King...they work great with very little work..
http://www.helidirect.com/product_info.php?products_id=4671
HDX 288mm Fiber FRP (White) Main Blades - Shogun/KingV2
Product Model EDN-1042
Availability
Price $14.95
(in reply to KCinNC)
       Post #: 9
RE: hbk2 main blade replacement - 5/10/2008 10:26:41 PM
DumbDawg
Status: offline
I've bought sets of blades from Fleabay and gotten some good deals... You have to know what you are buying tho.
I bought 5 sets for about $15 plus 10-15 bucks shipping. Which for woodies is ok... the really cheap ones that are black and 'look' like carbon fibre blades... are foamies. They work, will take a bit of beating but are limited.
Lots of blades for accidents, cheap enough to learn with especially. Going with tougher blades , ie plastics etc, means more torque applied to shafts and other parts if you get strikes. Translates into more costlier broken pieces. I'd stay with the softer blades, like woodies, because when you get strikes I've found there are fewer bent and broken parts afterwards. Just get a lot of wood shrapnel which can be spectacular at times...
But thats just my opinion.
Something had better fly
(in reply to selime)
       Post #: 10
RE: hbk2 main blade replacement - 5/10/2008 10:57:31 PM
funflier
Status: online
If you email cwtco direct they will cut you a deal on blades if you buy like 20 sets at once (40 blades). They will combine the shipping.
I sold my extras to the LHS and that more then paid for my own.
King ll, 3900 w/10t pin, Dynam 30A ESC, cnc head, cnc/trex tail, 43t upgrad, Telebee gyro, Dx6i Radio w/6100e, HS-65 servos
       Post #: 11
RE: hbk2 main blade replacement - 5/13/2008 1:00:35 PM
dafly
Status: offline
Thanks for all the info. I'm going to see what lengths the LHS has next time I'm there. I'm going to order some from the web for now though.
(in reply to funflier)
       Post #: 12
RE: hbk2 main blade replacement - 5/13/2008 2:50:18 PM
blk822
Status: offline
See if your LHS has blades for a venom 3dxl they will work. I have used them ,they are a fiber composite and will take a few hits.You just need to shim them to fit the HBK2 head. I beleive they are 288mm, work pretty good. if you use 315 or 325mm blades they will strike the tail blades.
I never crash.....I just land reaallllyyyy fast
(in reply to dafly)
       Post #: 13
RE: hbk2 main blade replacement - 5/14/2008 11:52:07 AM
rsking45
Status: offline
I like to use either the align 315 or325 pro blades.Ill cut the to size at end that goes into the blade grip.Ill out line the contour of a blade get the contour close using a razor blade
then finish it up by using a dremal with a round sanding disk.I like them better that the esky blades and the LHS alway has them instock
(in reply to blk822)
       Post #: 14
RE: hbk2 main blade replacement - 5/14/2008 6:05:44 PM
nuttcaze
Status: offline
Whoa, whoa whoa, you're out in Owego? Lol, lets get together and go fly sometime, you're only 15min down the road
(in reply to rsking45)
