finally found a gentle lady!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Gliders, Sailplanes and Slope Soaring >> finally found a gentle lady!
Page: [1]
Login
finally found a gentle lady! - 5/10/2008 3:55:42 AM
OzMo
Status: offline
Won a Gentle Lady on the EBA^ today. FINALLY and only paid 60 including shipping so it was reasonable. looking forward to a little kit bashing. I want to narrow the fuse to just fit my gear and put spoilers in the wing and change the foil to be the same as in the Alegro -lite. I may even add a polyhedral joint so the center can be flat. should be fun and cheap.
_____________________________
Yes dear, I did glue my hand to the airplane to keep from dropping it.
       Post #: 1
RE: finally found a gentle lady! - 5/10/2008 5:07:44 AM
kwmtrubrit
Status: offline
Do a build report on it, especially the airfoil changes.
Be an organ and tissue donor. Tell your family your wishes. It's your last chance to make a difference.
(in reply to OzMo)
       Post #: 2
RE: finally found a gentle lady! - 5/10/2008 5:59:55 PM
OzMo
Status: offline
I will post pics of the mods as I build it. good Idea
(in reply to kwmtrubrit)
       Post #: 3
RE: finally found a gentle lady! - 5/11/2008 1:54:13 AM
scaflock
Status: offline
The Gentle Lady is a good plane and a real floater. The light weight does make it a bit hard to handle in higher wind speeds. I can see making the fuselage narrower and changing the airfoil for better penetration when the winds are up. Adding spoilers will help you in a couple of ways. First the extra weight added by such a mod will help increase the wing loading a bit and the spoilers will give you more control of the glide path.
I just finished up building a GL for my girlfriend to learn to fly with. Since she's never flown before I opted to keep it totally stock to keep it simple for her. Had I been building it for myself, I'd have added spoilers and used the removable tip option.
(in reply to OzMo)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.234RCU1
