diff grease recommended
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Himoto Racing Support Forum >> diff grease recommended
Page: [1]
Login
diff grease recommended - 5/10/2008 2:12:35 PM
bkfamily1
Status: offline
On a Viper XET, what do you recommend for grease inside the differential case (where the planetary gears are)? What kind of lube do you use inside the gear box on the outside of the differential case (where the ring gear and pinion gear mesh)? I have been using just a general purpose lithium grease like you use in a grease gun for your car or tractor. But I do not know that it is good for the plastic. I do like the stiffness of that grease since it seems to give a bit more "posi-trac." I was thinking to maybe use a heavier grease in the rear for traction and a lighter grease in front for steering. Any input from your experience would be appreciated.
Thanks!
Bryan
_____________________________
Himoto Mega P MXB-3 and Viper XET - Traxxas Jato and TMaxx
The Revolution Has Begun! Come join the Family
       Post #: 1
RE: diff grease recommended - 5/10/2008 2:24:48 PM
ranger4x4
Status: offline
there isn't much you can do for the pinion and ring gear. the case isn't sealed. but for inde the diff carrier i use extreme pressure grease i think it's red made by valvoline. for the front you would want a lighter grease, like maybe regular diff grease i'm not sure on the weight of it maybe someone else can chime in and say which would be best for the front.
we are here to stay, the revolution has begun!!!!
(in reply to bkfamily1)
       Post #: 2
RE: diff grease recommended - 5/10/2008 3:42:05 PM
pede_kid
Status: online
I use lithium grease in my diffs
(in reply to ranger4x4)
       Post #: 3
RE: diff grease recommended - 5/10/2008 5:05:32 PM
HimotoRacingUSA
Status: offline
i use teflon grease.
OFFICIAL SUPPORT HIMOTORACING.COM / OWNER HIMOTORACINGUSA.COM
***Its me EHROOF!!!!*** THE REVOLUTION HAS BEGUN
(in reply to pede_kid)
       Post #: 4
RE: diff grease recommended - 5/10/2008 5:08:47 PM
Redharris
Status: offline
Bk.....
I dont think you need to worry about the Plastic being Sensitive to Petroleum Based grease...
I've used all sorts of greases in My Viper to no ill effect.......
Right now, I'm using some very thick Automotive axle grease (Pep Boys Auto Parts) inside my Rear Diff Capsule and on the Ring and Pinion.
Up Front, I use a lighter Bearing grease that I found at work...
Sorry....I know this answer is not very Scientific, But I tend to WING IT, when it comes to the Viper.....Lol.
OFFICIAL HIMOTO RACING SUPPORT - THE REVOLUTION HAS BEGUN
http://himotoracing.com :: http://himotoracingusa.com
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU1
