How tight should rotor blades be?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> RC Helicopter General Discussions >> How tight should rotor blades be?
Page: [1]
Login
How tight should rotor blades be? - 5/10/2008 9:01:46 PM
golfingguy27
Status: offline
Hey guys,
Progressing along on the setup of my first nitro heli. It's a used Evo 50 I bought here on RCU. I got to a point where I could run the engine some and get some gratification. I still have other things to set up before it's ready for it's first flight, but I have a question from running it up. As the rotor spools up and get's close to hover rpm it get's a relativley nasty wobble. I'm guessing it may be how tight I have the rotor blades?? If I remember correctly I read somewhere along the way that if it does that during spool up it's either to tight or too lose, and the opposite if it does it when spooling down?? The previous owner told me the blades are balanced and that they have been tracked so it shouldn't be either of those. Anything else I should check??
Todd
       Post #: 1
RE: How tight should rotor blades be? - 5/10/2008 10:16:14 PM
tadawson
Status: offline
A generally accepted "rule of thumb" for tightness is that if you hold the heli on it's side and gently bounce it, they should just begin to move . . . too tight gets you the shakes. Too loose, and they fold back on spoolup (or other things) . . .
- Tim
(in reply to golfingguy27)
       Post #: 2
RE: How tight should rotor blades be? - 5/10/2008 10:56:05 PM
BarracudaHockey
Status: offline
Tim is correct, hold it on its side and they should stay put, give it a shake and they should move. Also strive for approx even tension on the bolts.
Some (most maybe) helicopters go through a period or ressonance where they shake during spool up, the cure, if thats whats going on, is to power through it quickly and get the head up to speed.
_____________________________
Andy - Helicopter Forum Moderator
AMA 77227 http://www.jaxrc.com
(in reply to tadawson)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.547RCU1
