RE: SebArt Sukhoi 30E
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> RE: SebArt Sukhoi 30E Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: SebArt Sukhoi 30E - 5/27/2008 1:57:52 PM
latittude777
Status: offline
Yeah i was built in only a small amount of time. It took me a little longer than it should have just with modifying to fit servos but still very good build.
Yeah ive seen that movie and his harriers look so much better than mine. well actually alot of his flying looks better than mine!!!
Yeah your right about locking into knife edges...It doesn't seem to want to unless with a bit of speed..Slow it down and it starts dipping and doing funny stuff.
As i said before i'm using the thunderpower extreme 2200's so probably lighter than yours... I still think i need to move my battery more fwd...though i dont want to add weight to it, i reckon at 1.3 kg's without battery im probably on the heavy side of what i'd like to be... I'll have to see if i can move stuff around to get the weight more fwd.. or use an aluminium spinner back plate or something...just to get more fwd COG.
I cant say i've tried the rolling loop yet on mine..Rolling circles on the other hand i feel like a pro! So easy!
_____________________________
if the tail isnt touching the ground... then you aint low enough!!
(in reply to Cyberfyn)
       Post #: 26
RE: SebArt Sukhoi 30E - 5/30/2008 2:44:56 AM
latittude777
Status: offline
Hey boys,
Another great morning flying for me! I've managed to get the CG sorted i think...Cant tell you where it is exactly at this point in time as i've just thrown the battery in and found its sweet spot!
I havent used weights or anything like that, but putting my battery right up front against the firewall seems to be spot on. Its hands off when inverted, no climbing or diving but its improved the upright harrier heaps! I think you still need to be on the rudder heaps to keep it balanced but its now possible to do an upright stable harrier. Inverted harriers are still a piece of cake, no bad tendancies at all.
Only problem i have now is batteries.. Im overdrawing them or doing something to them as i have swelled 2 batteries in 2 flights. Both have since been replaced under warranty but that isnt the point. I need to try different props or something... Any ideas anyone?
I havent got anything to measure current draw either...
(in reply to latittude777)
       Post #: 27
RE: SebArt Sukhoi 30E - 5/30/2008 12:43:47 PM
Cyberfyn
Status: offline
What prop, Motor, batteries and ESC are you on mate?
I'm on 14/7E with the stock X55 Hacker ESC and A30 motor and a mix of Polyquest and Flightpower Evo25 3S cells. They do get quite warm, but nothing I'm worried about. I have heard that the recommended 15/7 prop is causing trouble though.
You really need to get/borrow a watt meter to diagnose it though.
Ian F.
Very funny Scotty, Now please beam down my clothes!
       Post #: 28
RE: SebArt Sukhoi 30E - 5/31/2008 2:26:08 AM
latittude777
Status: offline
Im using a Scorpion 70amp esc and hacker A30-10xl motor spinning currently a 14x7e APC prop.
I also tried the 13x8e prop but was dissapointed with its vertical pull out, though it did seem to spin this prop better.
I have just ordered a 14x7e and a 13x7e XOAR wooden props as i read somewhere they are better than the APC's and are more efficient. I'll give them a try and see how i go. My cells also get warm, but have never gotten real hot. My mate had hyperion cells he was using and these got too hot to touch and they still didnt swell. needless to say he ditched them. ( only rated at 15- 20c)
I'll see if i can get my hands on one, though being on a UNI budget doesnt allow for these luxuries.!!
       Post #: 29
RE: SebArt Sukhoi 30E - 6/1/2008 7:33:14 PM
Cyberfyn
Status: offline
My Polyquests get very hot but the Flightpower Evo25 only gets warm. Guess it's down to the C rating on them.
Had some great flight on her this weekend. Too quiet for me though
Ian F.
       Post #: 30
RE: SebArt Sukhoi 30E - 6/2/2008 12:51:00 AM
latittude777
Status: offline
I know exactly what you mean it barely makes any noise at all! I have noticed though it makes a wicked howly sort of cowl noise if you fly flat out past you. Sounds awesome!
If only i had the cash for a gasser! 35%er should do it!
My friend ran Hyperion cells in his sebart katana and was killing his batteries because of the C rating. When he finished his flight his batteries would be too hot to hold for any longer than 5 seconds... THATS HOT in my books! My batteries usually only get warm, once every now and again hot, but not too hot to hold.
I found one of my mates has an amp meter, so will hook up with him in the near future to check current draw to make sure im not cooking batteries.
I read somewhere else as well that XOAR props are supposed to be more efficient than APC props as well. So i have ordered a XOAR 14x7e and a 13x7e to test which is better.
WIll let you know the results when i get them back with my new packs. would be interesting to test against APC props as well.
< Message edited by scultura44 -- 6/2/2008 2:35:34 AM >
       Post #: 31
RE: SebArt Sukhoi 30E - 6/2/2008 12:15:02 PM
Cyberfyn
Status: offline
Yeah, keep us informed......... I'm strapping my ActionCam to mine this weekend
Edit..... Just had a look at the XOAR props & ordered myself a couple. Love a good woden prop
Ian F.
< Message edited by Cyberfyn -- 6/2/2008 12:22:25 PM >
       Post #: 32
RE: SebArt Sukhoi 30E - 6/2/2008 12:26:42 PM
latittude777
Status: offline
Action cam aye!!
nice one..Gonna post the videos up for us to have a look at? Post em on youtube, thats quick and simple and just drop the links here!
Yeah the wooden props do look a treat! Lets hope they perform well as well!
       Post #: 33
RE: SebArt Sukhoi 30E - 6/5/2008 8:24:18 AM
latittude777
Status: offline
Well i took the sukhoi out again today with the new XOAR 13x7 wooden electric prop and can safely say it was dissapointing.
I know the current draw was less, it did 3d etc..But when it came to vertical pullout...Nothing happened.
I was torque rolling only a foot or so off the deck and it became really fast in its spin.. I managed to be quick enough to catch it but when i gave it a blast of throttle expecting it to soar away... It didnt..It kind of hesitated for a second as if to think about it and then say..Oh all right stop nagging im going already!
So even though i havent measured current draw as yet, (hopefully in the next week or so) i dont think i'll be going back to the 13x7 prop.. It would be fantastic on 4 cell im sure but on the 3 cell it was dissapointing to say the least. And to top it all off, the batteries werent any warmer or any cooler than before!
It does however look ABSOLUTELY FANTASTIC on!!!
Will let you know how it goes with the 14x7 XOAR next flight time!
       Post #: 34
RE: SebArt Sukhoi 30E - 6/5/2008 12:43:50 PM
Cyberfyn
Status: offline
I Agree. The XOAR 13x7 is pants Did look good though.... Might try it on 4s. Won't fit in my spinner either without major surgery. I'm back with my good old APC-E 14x7
Let me know if the 14x7 XOAR is any better mate.
Ian.
       Post #: 35
RE: SebArt Sukhoi 30E - 6/5/2008 1:18:32 PM
latittude777
Status: offline
I managed to do surgery on the spinner and it fit ok without too many hassles. I only wish i had 4 cells to try it out on! (xoar 13x7 that is)
       Post #: 36
RE: SebArt Sukhoi 30E - 6/12/2008 3:41:39 AM
latittude777
Status: offline
Had another FANTASTIC flight today..
I love this plane more and more each time i fly it!
So the XOAR 14x7 seems to definately be the way to go. Havent tested the current draw yet but performance wise its fantastic. IS much quieter than the APC 14x7. The apc seems to make lots of cutting whiring noise in tourque rolls, harriers etc but the XOAR is quiet as! Its seems to be tourqier than the apc too. Its like it loads up at slightly lower rpm or something. Cant say for sure until i test it on the amp meter but will keep you informed. Besides it looks FANTASTIC!
Oh and i got sick of the landing gear splaying apart...Looks like it was doing a leg spread every time i came into land.. SORTED
I just drilled a couple of tiny holes in the trailing edge of the landing gear near the wheel axles and tied the two legs together with some real thin pull pull cable i had lying around. Makes it nice and stiff and stands proud now! And best of all you cant see it in the air! Personal touch that one, totally up to the individual!
Will post some pics later on!
       Post #: 37
RE: SebArt Sukhoi 30E - 6/12/2008 1:10:02 PM
Cyberfyn
Status: offline
Yeah, the ZOAR is a nice prop.... But to quiet I need it louder! Flying with a couple of other nitro birds in the sky mean I can't hear mine at all, and not having had such a big electric model before means I miss hearing what the motor is up to.
I like the UC mod. Can't do it to mine with the state of out field though. I'd end up cutting the grass My tail wheel keeps breaking, so I'm goind to loose it and just have a carbon skid.
Ian.
       Post #: 38
RE: SebArt Sukhoi 30E - 6/12/2008 2:09:20 PM
latittude777
Status: offline
Yeah it will only work if you have smooth ground to take off and land on. Otherwise you'll get caught up all the time. I havent had any drama's with the tail wheel yet, (touch wood) i guess a plastic skid is as good an option as any! Probably lighter too!
bugger about the noise factor though! I have to say im fortunate enough that all my mates fly electric also. Until that is they all plan to go GAS sometime before years end by which stage...ill understand your predicament!
       Post #: 39
RE: SebArt Sukhoi 30E - 6/14/2008 3:35:24 PM
latittude777
Status: offline
Ok so i finally have some fantastic news! I plugged into a current draw meter today and found that with the XOAR 14x7e im only drawing max around 36 amps... My batteries are rated for 55 amps constant and 110 burst so i am no where near the limit...Means i must have received a couple of duds or something! They replaced both under warranty so all is good! Looks like i'll be sticking with the Xoar 14x7 for sure!
As for the under carriage mod..I rethought the design after your comment about catching in the grass. Worked a treat. So i removed the old cable that joined both the legs together and made a new length that ran up through some holes i drilled in the centre of the mount. All i did then was cut a small groove in the mounting plate for the wire to run above the undercarriage between the 2 holes i drilled and ran it down the other side. Its all done with fishing quality coated fishing line and crimps. Neat, tidy and weighs nothing.. Best of all doesnt catch in the grass and is barely visible and still allows for minimal flex and holds strong!
Here are some pics, with the new XOAR prop and the new uc mod!
Thought i'd throw one in with the old AJ fliton as well just for good measure!
Click to see fullsize image.
Click for fullsize
Click for fullsize
