Tamiya Parts and source, advice Help needed!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> Tamiya Parts and source, advice Help needed!
Page: [1]
Login
Tamiya Parts and source, advice Help needed! - 5/10/2008 10:53:32 PM
blitzkrieg65
Status: offline
I know Karen at the tank museum can help with some of my questions, but I know some of you have the answers to the others!
Ok I am making a conversion that is all I can say,, but I may need a Tamiya Gearbox for the Pershing, plus the side gears that go in the housing, which allow the sprocket to set back? can you buy those ( Offset Gears pictured below ) or do they only come with the Tamiya Pershing kit??
Also how do you guys who have installed the DMD into Heng Longs interface with the turret wiring, do you have a picture or Tamiya skimatic??
Thanks for any help on this
The Blitz
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by blitzkrieg65 -- 5/11/2008 5:44:44 PM >
       Post #: 1
RE: Tamiya Parts and source, advice Help needed! - 5/11/2008 7:15:28 PM
pcomm1
Status: offline
Visit here for HL to Tamiya DMD conversation ideas: http://web.mac.com/ksoc/Special_Projects/Steve_Panzer_III.html#3
The HL turret rotation motor and the main gun elevation motor will plug right into the DMD Unit with a change to the the Tamiya DMD plug fitting and then operate as they should.
The airsoft unit is deleted. Email me off line for help in finding the 2 hard to get plugs that you will need for the conversion.
< Message edited by pcomm1 -- 5/11/2008 7:18:42 PM >
(in reply to blitzkrieg65)
       Post #: 2
RE: Tamiya Parts and source, advice Help needed! - 5/11/2008 8:09:38 PM
blitzkrieg65
Status: offline
quote:
ORIGINAL: pcomm1
Thanks, pcomm1 will check in with you! I don't know why I did not think to look on the SCAT site! The info was right under my nose if it was snake if would bit me!
The blitz
(in reply to pcomm1)
       Post #: 3
RE: Tamiya Parts and source, advice Help needed! - 5/11/2008 8:26:25 PM
TXtanker
Status: offline
Go to evil bay and type in JST connector and you will find what you need....
_____________________________
So many tanks so little time................
       Post #: 4
RE: Tamiya Parts and source, advice Help needed! - 5/13/2008 5:15:23 AM
astroboycp
Status: offline
Check your manual for the parts no, you should be able to order from Tamiya.
F a i l u r e i s t h e M o t h e r o f a l l S u c c e s
(in reply to TXtanker)
       Post #: 5
RE: Tamiya Parts and source, advice Help needed! - 5/13/2008 6:39:20 PM
Jeff489
Status: offline
Blitz,
If you need some additional Pershing info such as parts lists (to facilitate a Tamiya order), PM me, otherwise I hope to see you at DAK's battlday on May 31.
Jeff O.
(in reply to astroboycp)
       Post #: 6
RE: Tamiya Parts and source, advice Help needed! - 5/13/2008 7:29:26 PM
blitzkrieg65
Status: offline
quote:
ORIGINAL: Jeff489
Blitz,
Thanks Jeff,
As of this week, I think I may not need thsoe parts after all, but it is good to know who to get some info from!
I am fully planning on being at the Night fight in the Desert! It will be my first NIGHT battle and first battle with my KT!
I look forward to seeing you and Amee, maybe she with her Tiger and you and I with our KT's can get on the same team for at least one battle!
The blitz
(in reply to Jeff489)
       Post #: 7
RE: Tamiya Parts and source, advice Help needed! - 5/13/2008 8:46:00 PM
Jeff489
Status: offline
Blitz,
Time to get those headlights operational! You'll need them. Your KT looks really good. I'll be happy to see it in the dirt.
As to the battleday, it sounds as if there should be some new battlefield props and scenarios. Should be a challenge to all.
Jeff O.
       Post #: 8
RE: Tamiya Parts and source, advice Help needed! - 5/14/2008 8:21:00 AM
wackywheelz
Status: online
If by-chance you still need info on the parts, I have attached a picture showing the parts needed
Click for fullsize
< Message edited by wackywheelz -- 5/14/2008 8:25:44 AM >
Tamiya Sherman | Matorro KT | Bandai Hummel | HL Tiger (x3), Pershing, PzIII, Bulldog | T34/76 | 1/12 M1A2 | T34/85 (x2)
       Post #: 9
RE: Tamiya Parts and source, advice Help needed! - 5/14/2008 7:36:34 PM
blitzkrieg65
Status: offline
Thanks a lot Wacky!
Wow, there is much to go wrong with that rear end!
The blitz
(in reply to wackywheelz)
       Post #: 10
RE: Tamiya Parts and source, advice Help needed! - 5/15/2008 1:46:10 PM
heavyaslead
Status: offline
Blitz
You can get the gears, shaft, bearings or housing from Tamiya or Karen at AAF. I have done both.
Here are the parts:
Final gears 18T and 46T #9805849 (x2 packs)
Gearcase front and back #9805852 (x2 packs)
Large ball bearings 1280 #53066 (x2 packs)
Shaft bag #9415890 (x1 pack)
Small ball bearing 850 (x1 pack)
Cheers
Eric Scott
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
