bodywerks
AZ, USA Status: offline
There will be a gap, but the wire will fill most of it once it is in. IF you don't like the gap afterwards, seal it with some Blenderm tape. As for getting the wire through all the holes with little to no hassle, clean the wire with alcohol very good, sand the tip of the wire to a needle point, spray a light coat of WD-40 on it, chuck it up in your drill, and "snake" it through each set of hinges. using the drill is the real kicker here - makes the whole process a breeze. DO NOT go through the hassle of redoing the hinging, especially with robarts! There is not enough material for that style of hinge to install properly, for one, and you would TOTALLY defeat the purpose of the quick, simple assembly of this plane, IMO.
_____________________________
STRAIGHTEN UP AND FLY LIGHT!!!
