ravill
CA, USA Status: offline
Dom, I was plauged with powerfails in my kingcat with a p120 non-se. The jetcat folks thought for sure it was an ESD problem. I did not tell them I was running NiMH on both my reciever and ECU packs (parallel with the smoke pump), as I didn't think this was a problem. They had me hammer a stake in the ground and clip a wire to that stake and clip the other side to the brass fitting on the UAT during fill up. I also s/w a few people who had some similar experiences with using NiMH in their jets. As soon as I replaced the NiMH's with NiCD's I stopped having this problem, since I have stopped staking in the ground. Try a battery other than NiMH's in your system. I don't understand it either, because the car guys pull WAY more amps outta NiMH's than we EVER do in our jets. Some folks will say that even at very moderate loads (7-10 amps) the NiMH's can just drop enough voltage. Oh, and that blank screen with the green, and, or red light blinking, is the ECU "rebooting" after some sort of electrical disturbance. The only way to get any type of reading on the GSU is to turn the system back off and on again. Thus loosing your previous run info that could potentially show that "power spike". This was explained to me to be likely, ESD.... Raf PS: Just goes to remind you, that these toys are so UN-forgiving....
_____________________________
RAVjets Demo team. All We Do Is Fly.
