pilott28
Joined: 12/24/2002 From: Jacksonville, FL, USA Status: offline
quote:
ORIGINAL: MaJ. Woody 35 flights on my Panther now with the Titan SE and the problem has not shown up again. Just flight #4. Since this thread has picked up again, I'll relate my research on the "power fail" message. Essentially, what causes it is any event that leads to an ECU reboot. When the engine starts normally, the ECU sets a flag in memory that says "engine running". Normal shutdowns cause the flag to be reset to "stopped". This is the condition the ECU expects to see when it first wakes up and comes on line. When the ECU comes on line after an abnormal shutdown, it sees the flag set to "engine running" rather than the usual "stopped", and it realizes at that point that it was interrupted and reset. After the "oh crap" that goes through its electronic brain, it displays the "power fail" message. Dom, I had the same problem as you had on a cold, dry day and am pretty sure static electricity caused a spike that forced the ECU into an abend and reset. Never had a problem before or since. If an ECU or Receiver power problem causes the ECU to reset, the "power fail" message would also result. I asked about building in a delay, but when the ECU goes off line, the fuel solenoid always closes as a safety precaution. Building a firmware solution to introduce the delay would probably be a bit of an engineering challenge, even if power may still be available from either the receiver or ECU battery. Thanks to Bob Wilcox for taking the time to explain all this to me.
_____________________________
Keith Sievers
