MaJ. Woody
NY, USA Status: offline
By the way my ECU battery was at 7.8V. I was just reading about static electricity in the Jetcat Support forum. Funny thing was that the loose grass around the airport was stuck to my Jersey Modeler can. I could not wipe it off. I had to blow the grass off the fuel can. Do you thing I had a static electricity issue? My fuel can was almost empty if that mean anything. Here is the post from the other forum I was reading: Jetcat experts, Can you tell me specifically what can cause a PowerFail Error message? Is it power loss from the receiver battery only? Or power loss from the ECU pack only? Or perhaps either can cause this message... My Titan shut down during midflight. After "landing" the model, we attached the GSU to the ECU, and we could not read the output - the GSU character field was filled with very dim text boxes. After relocating the model, and doing a quick check on the ECU pack, we were able to read the PowerFail message. Post-event, the receiver pack read 5.2v with a mild load, and ECU I believe was reading 7.5v with a very short duration 1.0A discharge. Tomorrow, I will discharge both packs (NiCd), but I am confident they will be of good capacity. Thanks for any suggestions... Update - I just got off the phone with Bob Wilcox, and he strongly suspects I've been bitten by the static electricity buildup issue, from the fuel lines. I'll eventually post later after I get some addtnl flights, to see if this can be confirmed. _____________________________ -Ron S.
Dom Team FeiBao
