AIRPLANENUTS
GA, USA Status: offline
Guys, I have an older G-38 with the original carb w/no choke. I want one w/ a choke, and I've read the WT-540 is a great replacement, and Horizon shows the WT-338 as the o.e. replacement. Does anyone know if either or both carbs will fit the spacer block on my old engine, with the same odd-ball linkage as the original? Do you have a good source for your carbs? Thanks, Rick
_____________________________
"Futaba gets it right the first time."
