issues with xcelorin usb adapter
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric On-Road vehicles, race cars and more >> issues with xcelorin usb adapter
Page: [1]
Login
issues with xcelorin usb adapter - 5/11/2008 11:14:28 AM
eckosof
Status: offline
bought xvelorin 7500 kit, came with usb adapter and software to program ESC. after installing software and hooking up usb adapter it will not go green no matter what i due, anyone have this issue? or did this work for you?
_____________________________
XXX-S - Xceleron 7500Kv - Venom 5400 11.1v 3S Lipo
Jato 3.3 - way to many hop-ups to list
       Post #: 1
RE: issues with xcelorin usb adapter - 5/11/2008 7:28:00 PM
TIGER76
Status: offline
Make sure the program drivers are all in m8 uninstall it restart pc and reinstall again and see if it sorts it,when u plug the usb in it should pop up by the windows time to say its working ie new device etc.
also check device manager to make sure the drivers are installed properly.
VXL pede/ 9.6v 4200 mAh & 8.4v mAh
TT-01r / Quake ESC / Trinity D6 9Turn / Orion Rocket Pack 4500 (X2)
(in reply to eckosof)
       Post #: 2
RE: issues with xcelorin usb adapter - 5/11/2008 8:40:48 PM
eckosof
Status: offline
yea i have made sure drivers are correct, even going to the point of finding exactly what drivers are used and finding newer versions for them. this make me wonder, taken from manual "You will be prompted to install the device drivers, they are both unsigned so
select OK and continue.". when i reinstall i verify all traces of software are removed, and cleaning with CCleaner, and registry mechanic, also i put Kaspersky on standby while i do the install to ensure nothing is blocked during install, and after checking logs i verify kaspersky didnt create any conflicts with install. I think at this point im just going to have to call horizon.
(in reply to TIGER76)
       Post #: 3
RE: issues with xcelorin usb adapter - 5/11/2008 8:43:51 PM
rschuur
Status: offline
Some Anti-Virus programs are preventing the DRIVERS to install, AVG must be stopped for installation.
The other thing that will prevent driver install is NOT installing with Full Administrator Rights, and on VISTA you must use the "run-as" feature and actually use the Administrator account.
hope this helps.
       Post #: 4
RE: issues with xcelorin usb adapter - 5/11/2008 9:05:17 PM
eckosof
Status: offline
i do have full admin, i build this machine, im using xp with sp3, i use kaspersky instead of avg cause it has much better protection and bigger databases, and i pause the protection while installing. im gonna try uninstalling everything one more time before calling horizon. thanks for the help
(in reply to rschuur)
       Post #: 5
RE: issues with xcelorin usb adapter - 5/11/2008 9:20:33 PM
eckosof
Status: offline
yep still doing it, i uninstalled, rebooted, paused protection, reinstalled, connected, prompted for drivers, allowed to search, unable to find, no green light. going to reboot one more time and see if it goes.
       Post #: 6
RE: issues with xcelorin usb adapter - 5/11/2008 9:39:42 PM
eckosof
Status: offline
i just tried it on brother in law's computer and it doing the same thing, only on his machine (vista) i says there are no drivers installed for device.
       Post #: 7
RE: issues with xcelorin usb adapter - 5/11/2008 9:49:51 PM
eckosof
Status: offline
found this, going to try and let you guys know
http://www.silabs.com/tgwWebApp/public/web_content/products/Microcontrollers/USB/en/mcu_vcp.htm
       Post #: 8
RE: issues with xcelorin usb adapter - 5/12/2008 3:36:38 AM
eckosof
Status: offline
just took out the car for the first time with new battery/motor, Holy god, lets just say i had to place a order with horizon for some new arms, might be 2 fast. will try to run again when its dry
       Post #: 9
RE: issues with xcelorin usb adapter - 6/20/2008 7:09:22 AM
isdedina
Status: offline
Hello, could you please describe the procedure with USB driver installation on Vista system? I have the same problem, thank you.
       Post #: 10
RE: issues with xcelorin usb adapter - 6/22/2008 9:19:30 AM
eckosof
Status: offline
i havent gotten my to ever work
nor have i called losi because its impossible for someone to help you over the phone with computers......
(in reply to isdedina)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
