Duralite 6V/7.5A regulator
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Duralite Support Forum >> Duralite 6V/7.5A regulator
Page: [1]
Login
Duralite 6V/7.5A regulator - 5/11/2008 8:43:13 PM
ggroyal1
Status: offline
I have been using Duralite 6volt/7.5 amp regulators in my 50cc gas planes for almost two years without any problems. I use a 4300mah lipo for the receiver and a 3400mah for the ignition(DA50). I see you are now selling A123 batteries(on sale thru May 31). I have the JR9303 2.4Ghz radio and JR servos that Horizon says not to exceed 6 volts. My question is: Can I use the Duralite 6V regulators with the A123 packs to make sure I do not exceed 6 volts to the servos? I have been told I can use just the A123 batteries(6.6 volts).
George G. Royal
       Post #: 1
RE: Duralite 6V/7.5A regulator - 5/12/2008 5:24:41 PM
DuraliteTech
Status: offline
Hi George,
Yes you can use the 6 volt regulator with the A123's to keep the voltage of the servo at 6 volts. We know that many pilots are using the A123 with servos rated at 6 volts without any issues.
You might want to check with some of the JR Team Pilots to see what their experiecens are with the A123's direct without regulators. It is expected that you experience faster response, higher torque and they will wear a bit faster.
_____________________________
Mark
Duralite Tech Support
(in reply to ggroyal1)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.188RCU1
