rotarydoc
MD, USA Status: offline
Hi Def, Yeah, it sounds like it just some normal spin-up vibration, most helis do that to some extent, alot of times, it's just the blades getting seated in their flying position. I wound not worry about it unless it seems like it's vibrating alot when in a hover. It sounds like an adjustment on the 3 in 1 for the turning right at a hover. It's explained pretty well in the manual how to adjust it. If you need some help adjusting it, let me know, and I can help walk you through it, if you want. You will enjoy the CX2, I know I did, and still do, but it's not the same as flying the B400...it will be great for you to learn orientation...it would be good to practice some nose-in and side in hovering when you get comfortable with it. This will make it easier to fly the CPP as well. Thanks, I had pretty good weather here, just a little breezy. I flew very well, only two battery packs, but I was doing figure 8's, which I have never done before, so it was well worth going out and flying! I also got my original CPP flying well again, it was one of the servos, the only one I did not replace. I stole the servos out of the new CPP! lol The tail still wasn't acting too well, but I think a new motor would help alot. It was also a little windy, which the CPP doesn't like too much, as you know... Did ya get the RC cars fixed? Hope there wasn't too much damage. I felt so sorry for you when I read your post today, I was hoping you wouldn't give up! I'm glad that you got back on the horse, so to speak, and put the blades on and flew anyways! Glad it all turned out Ok when you went flying. So, I have to ask...do you think flying the CPP is harder, easier, or about what you figured on before you got it? Just curious, I hope we didn't mislead you...but if you stick with it, you will get better, and more confident! Hope your CX2 comes in soon! I hit a wall with mine today...it was fine, just had to straighten the flybar...they are pretty tough! Keep in touch, Glenn
