RE: buying first blade, whats the best?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> RE: buying first blade, whats the best?
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: buying first blade, whats the best? - 5/13/2008 12:08:48 PM
forrest225
Status: offline
quote:
ORIGINAL: Deftones123
nah I bought from this person before, many times before
oh cool. i might buy from them somtime then
(in reply to Deftones123)
       Post #: 51
RE: buying first blade, whats the best? - 5/13/2008 3:17:50 PM
tyrick69
Status: offline
Just wanted to add my $.02. When I was first looking at purchasing an RC heli, I too was worried about getting bored too quickly. I did a lot of reading on the forums before making my decision and even though some advised against it, I went out and purchased a Blade CP. I went through what seemed like an endless cycle of get the heli in the air, hover for 5 to 10 seconds, and then crash. I spent much more time fixing the heli than I actually did flying the thing. Finally, after a month or two, I lost interest and put it in the closet. I literally didn't fly the thing for almost a year. I was hanging out with a friend who had a Lama coax and he asked me if I wanted to try it one day. I found it much easier to handle than the CP. I decided that despite the fact that I would probably outgrow it pretty quick, I needed to have a coax heli. I went out the next day and bought a Blade CX2. I found it to be super stable, and all around, easier to fly than the CP. True, you really can't fly it that much outside, but it really does help your coordination and orientation. After a week or two of tooling around on the CX, I decided to bust out the CP again. To my amazement, I could actually fly the thing. Flying the CX2 for a couple of weeks had actually improved my overall ability by leaps and bounds. I still fly the CX2 occasionally, especially on rainy days. It's great for working on your nose in and side in orientations because it doesn't take off on you like the CP does and it's alot easier to recover if you do move sticks in the wrong direction. The point to all of this is, that while you probably will get bored with something like a CX within a couple of weeks but it's still a great heli to learn on. I probably spent more in parts for the CP in the first couple of weeks of attempting to hover, than the CX2 cost. In other words, I could've bought a CX2 first, and then a couple of weeks later, bought a CP with the same amount of money I originally spent on the CP and replacement parts.
(in reply to forrest225)
       Post #: 52
RE: buying first blade, whats the best? - 5/13/2008 7:39:02 PM
Deftones123
Status: offline
yeah forrest I bought from that guy on ebay before, very nice people and very fast shipping, thanks for the adivce tyrick69, I guess ill learn flying the hard way when I get my cp pro lol
(in reply to tyrick69)
       Post #: 53
RE: buying first blade, whats the best? - 5/13/2008 8:07:55 PM
tyrick69
Status: offline
lol, good luck. You definitely can learn to fly on the CP but the Pro will be even wilder because of the Bell Hiller. Just take your time and if you have the patience, follow Radds. I didn't have the patience to keep it on the ground that long. Whatever you do, don't give up. There's nothing like that feeling you get when you realize you're finally flying this thing, instead of the other way around.
       Post #: 54
RE: buying first blade, whats the best? - 5/13/2008 8:59:41 PM
Deftones123
Status: offline
follow radds? I can't give up, i wanna have something to do with my father inlaw when u goes out to the fields, so im going to keep at it for however long it takes, they look like a blast when you can fly them though
       Post #: 55
RE: buying first blade, whats the best? - 5/13/2008 9:44:15 PM
rotarydoc
Status: offline
Hey Def,
Yes, RADD'S....Radd's school of rotary flight...if you don't get a simulator, I highly recommend at LEAST reading what Radd's has to say...if not praticing it...
You can find it easily....just do a google search for "radds" or radds school of rotary flight" ...it should come right up....well worth reading !!
Glenn
       Post #: 56
RE: buying first blade, whats the best? - 5/13/2008 10:35:02 PM
Deftones123
Status: offline
I deff will read it because I want to learn to fly the right way
(in reply to rotarydoc)
       Post #: 57
RE: buying first blade, whats the best? - 5/13/2008 10:43:47 PM
Deftones123
Status: offline
do you have to do a breakin procedure on the heli or motors in the heli, run it at low speeds for the brushes in the motor to set?
       Post #: 58
RE: buying first blade, whats the best? - 5/14/2008 2:49:53 AM
Deftones123
Status: offline
only reason im asking is because when I race my electric trucks, before I use a new motor I run it at quater throttle to let the brushes set.
       Post #: 59
RE: buying first blade, whats the best? - 5/14/2008 3:43:27 AM
rotarydoc
Status: offline
Hey Def,
It's probably not a bad idea to break in the motor, but not many people bother...I didn't. I also used to race RC cars, and the break in was critical, even just when doing new brushes....those motors are stressed to the max, and probably benefit from the break in procedure. The heli motors are not under nearly the amount of stress and heat that RC car/truck motors are exposed to...so personally, I don't bother.
Not to mention that the motors are dirt cheap compared to RC car motors....the main motor for the CPP is $10...same for the tail...$10...won't break the bank if you need to replace them...and you will, the tail at least....the main motors seem pretty durable. I do lubricate the bushings however, every few flights...seems to help them last longer.
Don't worry too much about the tail motor at first, it should do you well for quite some time...but it tends to take quite a beating when a new pilot is in the learning stage, as you will find out...you will have numerous tail rotor strikes with the ground; however, rarely does this do any serious damage to anything...the tail has a neat setup that allows it to take quite a bit of abuse without really breaking.
Good luck with the new CPP...any idea of it's arrival time?
Glenn
       Post #: 60
RE: buying first blade, whats the best? - 5/14/2008 3:53:44 AM
Deftones123
Status: offline
ordered it last night, prob the lastest it will be here is saturday, so in the next week, pretty excited to get it
       Post #: 61
RE: buying first blade, whats the best? - 5/14/2008 3:56:03 AM
Deftones123
Status: offline
tommorrw im going to go to my lhs to see what he carries as far as parts, I know he has tons of cx2 and cp parts there, but I wanna see if im going to have to order certain things online
       Post #: 62
RE: buying first blade, whats the best? - 5/14/2008 3:59:41 AM
rotarydoc
Status: offline
Yes, I'll bet you are excited! You will have a great time with it, I am sure. I am also very excited, although probably not as much as you are...I am getting a second B400 from an eBay seller, at first, I was just going to get a bare bones "spare kit" heli with no electronics....but ended up deciding to get the whole shooting match instead called a PNP (plug n play), with all electronics, etc. Literally just add a battery and transmitter, and go flying...can't wait...it will be nice to have a back up heli...in case of a major crash !!
Let us know when you get the bird, and read up on RADDS, and get those flybar weights soon !
Take care,
Glenn
       Post #: 63
RE: buying first blade, whats the best? - 5/14/2008 4:03:23 AM
rotarydoc
Status: offline
Thats a good idea, kinda feel out what they have in stock, like stuff you are likely to break...blades, landing skids, those pins for the main gear, stuff like that. It's hard to predict what you will need/break, but it's good to know what the LHS has in stock...
I like to buy from the LHS, because I want them to stay in business, I need them to be there when I need stuff! It costs more sometimes, but not really, there is not much discounting on the Efite parts that I have seen anywhere...
Glenn
       Post #: 64
RE: buying first blade, whats the best? - 5/14/2008 6:12:44 AM
evdreamer
Status: online
My sister used to race trucks as well. She was one of the best drivers in our town. It probably helped that she had a connection to get highly modified ESC and motors. Then I have a twenty year old RC10. By the time I was old enough to race the program fell apart. I didn't break in the motor for the CP Pro either.
Nick
_____________________________
Since I started this hobby money seems to keep disappearing. :)
T-Rex 450SEV2, Gaui 200 SD
