rotarydoc
MD, USA Status: offline
Hi Chief, The B400 is an excellent heli, as good as most any lower cost collective pitch heli, maybe more so than some, because of it's size and stability. No matter what, it's going to be very difficult to fly compared to the CX2!! If you have the simulator, I have to think you have experimented with the helis? That should give you some idea of the difficulty involved... The biggest drawback to the B400 as a first CP heli is it's inherent complexity, the rotor head is pretty a pretty complex thing, (the CP pro is quite a bit simpler) and it will need fixing WHEN you crash... its' also a bit heavier than some smaller heli, usually results in more damage WHEN you crash...not IF....LOL It is also very difficult to find training gear for it at the moment...I have tried, so you'll probably end up making your own...it's not hard, and is mandatory for the new heli pilot... It is much easier to learn on than say, a CP, or CP Pro, by virtue of it's larger size, and additional stability...and the major plus of a belt driven tail... vs. motor driven...belt driven tails are the way to go! I went the step up route...CX2, to a CP Pro...to the B400....I could have easily bypassed the CP Pro, and been OK... but to be honest, the little CP Pro is still a lot of fun...not very stable..but fun!! Hope this helps... Glenn
