rotarydoc
MD, USA Status: offline
Hey Def, The blades I am running and really love are from Helidirect, do a search for HD1141....they are $8.00 a set...the holes are too big in the blades, but they give you nice, perfect size brass eyelets to go in the blades to fit the CP Pro grips and blade bolts. The modding involves sanding or filing a small amount of material off of the inboard end of the blades ( I used a file, took maybe 5 minutes for both blades) so that the blades can swing freely in the grips/holders. Not a big deal, really. I really do like these blades, the price is right, and the fact that they are heavier than the stock blades adds stability to the heli. I flew mine again today, and it flies like a dream with these blades...I had a hard landing, but did not have another tailboom strike like before, I think that was a fluke of some kind. There are also many types of plastic blades out there, but I have been avoiding them...the biggest drawback is that they are so strong, when you DO hit something, which you WILL, it transfers alot of the impact to other parts of the rotor head, main shaft, spindle, servos, etc....I would rather replace a few sets of blades than main shafts, spindles, servo gears, etc when I crash, so I stick with wooden blades, they tend to absorb alot of the impact of a blade strike. The service from Helidirect has been awesome, I highly recommend them! Glenn
