RE: Flaming Falcon Shutdown
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> Artes Jet >> RE: Flaming Falcon Shutdown
Page: <<   < prev  1 [2]
Login
RE: Flaming Falcon Shutdown - 6/1/2008 5:20:16 AM
smitty1001
Status: offline
Eric,
Got it back yesterday! Three flights today!!
Unbelievable service as usual!
Thanks a million!
It's Powermax all the way for me from now on BTW.........
Smitty
_____________________________
Own: Jet Central Falcon, 2 Super Bees!
(in reply to BluFox)
       Post #: 26
RE: Flaming Falcon Shutdown - 6/19/2008 12:45:23 PM
Mavrik!
Status: offline
I have a Falcon and was wondering what their actual thrust is. I note some websites quote 22 pounds and others quote 23 pounds thrust??? All of the other Artes range turbines have constant thrust ratings. Mine is serial number 145!
Mav
(in reply to smitty1001)
       Post #: 27
RE: Flaming Falcon Shutdown - 6/19/2008 10:58:12 PM
rorrock
Status: offline
Mav,
Brett and I did our standard pre-delivery run up of a customers falcon yesterday, and it was reading 22+ pounds on our test bed.
I would say the 22lb rating is spot on, however do not be surprised if it puts out a little more than that.
Regards,
Rob
AusJets
Jet Central ,X-Treme Jets, RoJets, JetMach dealer
(in reply to Mavrik!)
       Post #: 28
RE: Flaming Falcon Shutdown - 6/20/2008 12:06:40 AM
Mavrik!
Status: offline
quote:
ORIGINAL: rorrock
Mav,
Regards,
Rob
Cool, also it states max rpm 122k on some sites, but the manual states max 126k? What should the max rpm be set at for max thrust? I note I have programmed mine at 126k rpm per manual and sometimes it goes to 128k rpm if you slam stick it? Is that safe?
Mav
(in reply to rorrock)
       Post #: 29
RE: Flaming Falcon Shutdown - 6/20/2008 12:12:21 AM
noahb
Status: offline
rorock, have you ever ran a superbee and measured the thrust? Just wondering.
       Post #: 30
RE: Flaming Falcon Shutdown - 6/20/2008 1:51:07 AM
rorrock
Status: offline
Noahb,
The day before the falcon we did a run up on a SuperBee and got 13.8lb on it.. And acceleration that just blew our minds..
Regards,
Rob
AusJets
(in reply to noahb)
       Post #: 31
RE: Flaming Falcon Shutdown - 6/20/2008 2:35:55 AM
knobby1
Status: offline
Hey Noahb,
Yes, as Rob has stated, I ran the "SuperBee" a few days ago and was astounded at the acceleration rate and static thrust from such a small engine, I thought my thrust gage was incorrect and had it calibrated again, only to find it was correct to start with..!! The "SuperBee" is indeed a fine engine with exceptional performance.
Steve (Mav),
The Falcon is also a fine engine, although I don't need to tell the owners of them this. As with the SuperBee, the Falcon also has exceptional acceleration and performance. I test them at very close to sea level with good, cool, dense air so the quoted static thrust figures are pretty much spot on. Rob and I at AusJets.com are able to give first hand experience of how good the Jet-Central engines and service is, at this stage....second to none!!
Cheers,
Smithy.
Brett Smith
AusJets.com.....Jet Central turbine engines, Jet-Joe engine service.
       Post #: 32
RE: Flaming Falcon Shutdown - 6/20/2008 2:54:20 AM
noahb
Status: offline
I have two of the super bees, and the acceleration is very good.
In the air however, it's a lot faster.
(in reply to knobby1)
       Post #: 33
RE: Flaming Falcon Shutdown - 6/20/2008 3:01:10 AM
smitty1001
Status: offline
< Message edited by smitty1001 -- 6/22/2008 3:47:45 AM >
(in reply to noahb)
       Post #: 34
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.549RCU1
