Calin666
UT, USA Status: offline
Thanks zake, I have found that you seem to have some good advice. I looked around, and can get a Novak XRS Sport ESC for $52, so that won't kill me. As for shock oil, I was thinking maybe 30 weight, and use the large preload spacers all around. I will check the spring selection out at my LHS, they usually have a good selection of Tamiya hop ups. I also just remembered that I can get a 2S, 4000mah lipo pack from another LHS for $75, and pick up in inline balancer for another $30, so I may do that, I need to look at what the possibilities are for batts. Zake, since I know you know something about the TA05, is there an easy, quicker way to adjust the tension on the belts, than to take the bulk heads apart? My belts are ok, but seem just a little bit loose, and I wouldn't mind increaseing the tension just a little bit, a couple of notches maybe, unless it is going to be a huge pain.
