Are You Happy With Your JR Conversion Too 2.4ghz?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Are You Happy With Your JR Conversion Too 2.4ghz?
Page: [1]
Login
Are You Happy With Your JR Conversion Too 2.4ghz? - 5/12/2008 4:06:15 AM
Rcpilot
Status: offline
I have a borrowed DX-7 and a couple AR7000 RX's from a buddy. I like it so far. I want more channels though and the 9ch Spektrum is too much $$$ for me right now.
I'm thinking about buying a module for my JR8103 and converting it to 2.4ghz. I realize the wire hanging out the back is an issue for some guys. It kinda bugs me too, but it is what it is.
Are you happy with the module conversions so far? What radio did you convert? Any issues?
_____________________________
Airplanes have expiration dates. It''s just not printed anywhere on them.
I''m not really an airplane pilot; but I did stay at a Holiday Inn Express last night.
       Post #: 1
RE: Are You Happy With Your JR Conversion Too 2.4ghz? - 5/12/2008 5:41:47 AM
BuschBarber
Status: offline
I converted my 9303 to 2.4 using the Module, last year. I have had no problems and I am gradually acquiring more 2.4 receivers. The wire coming off the module is not a problem. I have two 9303's so I use one with my synthisizer module (72Mhz) and the other with the 2.4 module.
It is very convenient and Model Match does not mean enough to me to buy the X9393 2.4. Perhaps the 12 channel in the future.
(in reply to Rcpilot)
       Post #: 2
RE: Are You Happy With Your JR Conversion Too 2.4ghz? - 5/12/2008 1:55:47 PM
krossk
Status: offline
I just added the module to my 8103 and (so far) am pleased with the results.
I haven't used it for more than hovering my electric heli in the driveway, so I haven't really field tested it yet.
But given that I now have 6 Spektrum receivers for my planes, I'm kind of committed...
(in reply to BuschBarber)
       Post #: 3
RE: Are You Happy With Your JR Conversion Too 2.4ghz? - 5/12/2008 6:11:12 PM
Gordito Volador
Status: offline
I bought a module for my 9303 and it works great. The wire out the back is really a non-issue.
Regards, Bill
"Let Me Hear Your Guns"
(in reply to krossk)
       Post #: 4
RE: Are You Happy With Your JR Conversion Too 2.4ghz? - 5/12/2008 7:17:58 PM
dirtybird
Status: offline
I just watched an ASSN module in a Futaba 9c. It worked fine. The TX module costs $70 and the receiver is $25 at ****
OOPs the price is higher. $90 & $32.
< Message edited by dirtybird -- 5/12/2008 7:23:34 PM >
(in reply to Gordito Volador)
       Post #: 5
RE: Are You Happy With Your JR Conversion Too 2.4ghz? - 5/12/2008 9:10:40 PM
codimasta
Status: offline
I converted my 9303 with the module..to 2.4...I did convert it to run the line inside..it looks like a regular 9303/2.4
The conversion is featured in one of the threads
       Post #: 6
RE: Are You Happy With Your JR Conversion Too 2.4ghz? - 5/14/2008 2:46:42 AM
lou1947
Status: offline
I have a 9303 with a 2.4 module and can not tell the difference from a x9303.. A buddy of mine has a Yak 54 just like mine and with the same motor, we have flown both planes, his with a x9303 and mine with the module and we cannot tell a difference flying with a x9303 or with my 9303 with the module. So go for it.
(in reply to codimasta)
       Post #: 7
RE: Are You Happy With Your JR Conversion Too 2.4ghz? - 5/14/2008 6:21:28 PM
vasek
Status: offline
I have a 2.4 module in a JR/Graupner MX22
I am very pleased with the outcome, however I did have an issue with the Battery Charge Display on the Tx
It showed a current drop of 1.2 V in certain stick positions. Luckily it is only the display that is faulty as the current stays constant even though the display shows otherwise (I had it checked) BUT it had me worried for a while!
I must add that this condition is directly linked to the 2.4 module as the display is normal if the standard (original) module is used
V.
I am a proud Canadian >living in Europe;-)
(in reply to lou1947)
       Post #: 8
RE: Are You Happy With Your JR Conversion Too 2.4ghz? - 5/14/2008 7:42:07 PM
mcdonald77
Status: offline
I just got a 9303 2.4, set up a cermark f16 using a 7 channel and a f15 ducted fan using a 7 channel. its an awsome setup compared to my old 8103. I like that fact that if the model number is wrong it wont connect to the receiver turned on.
(in reply to vasek)
       Post #: 9
RE: Are You Happy With Your JR Conversion Too 2.4ghz? - 5/15/2008 3:02:40 PM
Eric.Henderson
Status: online
So far I have converted
347 Plane and car
388
8103
10SXII
10X
and a 9303 for a buddy.
All function well. I did add a 1/4" square of self adhesive soft Velcro to one side of the module to stop them moving. Otherwise they are all doing their job.
Regards,
Eric.
If it has wings I''ll fly it....
(in reply to mcdonald77)
       Post #: 10
RE: Are You Happy With Your JR Conversion Too 2.4ghz? - 5/15/2008 3:11:34 PM
krossk
Status: offline
quote:
ORIGINAL: Eric.Henderson
I did the exact same thing to my 8103 conversion. I just didn't have enough faith in the latch that it would not eventually allow the module to fall out - but the velcro filler addressed all fears!.
(in reply to Eric.Henderson)
       Post #: 11
RE: Are You Happy With Your JR Conversion Too 2.4ghz? - 5/15/2008 4:20:43 PM
JohnVH
Status: offline
I recently converted my 10X and 8103 with the module, so far so good, Ive only put it into a .91 glow bird, and a zenoah gas powered Helicopter, and another into a flight metaled glow powered T6... I need to trust it before putting it into 150cc and jet birds. But so far I like it, not having to worry about a freq pin, being shot down, simplicity. yay! I am however not the biggest fan of the extra receivers yet, but oh well.
Just a note, having some issues in the T6 with the JR921... fussy little receivers to get right..
< Message edited by JohnVH -- 5/18/2008 11:40:43 PM >
---AIR VH---*FURY FLYER* www.3DFoamy.com
       Post #: 12
RE: Are You Happy With Your JR Conversion Too 2.4ghz? - 5/15/2008 10:41:20 PM
salmon
Status: online
can someone post the link of the place that sells the 2.4 module and RXs?
(in reply to JohnVH)
       Post #: 13
RE: Are You Happy With Your JR Conversion Too 2.4ghz? - 5/15/2008 10:48:50 PM
JohnVH
Status: offline
www.donalds-hobby.com
they have awesome prices, highly recommended.. At items to your cart for the best price.
(in reply to salmon)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
