Mr Cox
Joined: 7/20/2007 From: Gothenburg, SWEDEN Status: offline
Ok, the thread is here: http://www.rcuniverse.com/forum/m_6720213/mpage_11/key_/tm.htm Some data and modifications (from that thread): Ok, we finally had some sun here today and I have some tachreadings. Used a graupner 6x3 and a less than 15% nitro (lowered bacause I added a bit of extra castor to a 15% blend). Original head and OS#8 plug: 17400 rpm at max with a very nice idle at 3000 (min around 2800), very smooth running. Home-made turbo head and OS P7 plug: 18700 rpm at max with good idle at around 3200 (min appr. 3000), a destinctive change in note compared to the standard head and a nice "scream" to it. For the turbo head I just tried to copy the original head dimension but with a turbo fitting using the guidlines by Japanman and Andy. I used a center drill for the most part and only finish the vary last bit using a sharpened PH#3 bit. To mee it seems like the center drill doesn't quite have the angle to it, while my PH#3 bit wasn't good enough to really cut away material it only seemed to scrub material away... I have made a few other alterations but nothing major really: - sealed the back cover with teflon tape - made a growe for the o-ring in the muffler - deburred the exaust to 4 mm - dremeled out the throttle barrel to an more even diameter of about 3.5 mm. The original tapers from about 3.5 to3.2, and I think this restricts the intake as well as rendering the air bleed screw useless. One odd thing remains to be fixed. The pin that aligns the liner is the hollow type (!) and this of course leaks... I will try to fit a solid pin there instead. I haven't touched the transfer channels (yet) but there is probably a bit more to gain there, I'm not sure that I will nead that in a sports engine though.
