What Fairchild was it?
Tower Hobbies
Logged in as Guest
  Printable Version
REPUBLIC P-47 104" WS BUD NOSEN - ARC
Seller:  N215PB
Details:   $1,800.00   |  7/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Full Scale planes, cars, helis, boats >> Airplanes - Full Scale >> What Fairchild was it?
Page: [1]
Login
What Fairchild was it? - 5/12/2008 7:22:27 PM
griesel
Status: offline
Jan - Mar 1953; Arsenal Technical High School; Indianapolis, Indiana; Airframe shop.
The instructor had his own airplane in for restoring. It was big; green; had a big
radial up front and was a Fairchild. He said it could haul a pilot, full fuel and a ton of
freight. What I can come up with is a model 71 or earlier version; except that this
plane had a wheel instead of a stick. He was going to fly Alaska bush with it. All the
pictures of 71 cabins show a stick. Which Fairchild was it?
< Message edited by griesel -- 5/12/2008 7:26:16 PM >
       Post #: 1
RE: What Fairchild was it? - 5/12/2008 7:26:56 PM
TJR1
Status: offline
Is it possible you are mistaken and it was a Stinsen?
_____________________________
Check your six... I might be on it!
AMA#: 741093 Member: Azalea City Model Aeronautics
(in reply to griesel)
       Post #: 2
RE: What Fairchild was it? - 5/12/2008 10:44:04 PM
Robinaire
Status: offline
Back then, there were still some 1930s area Bellancas in use, which were real load carriers, especially the one with wing-shaped struts! Can't recall the model. I'll check my Janes. Lee Robinson W.P.B.
       Post #: 3
RE: What Fairchild was it? - 5/12/2008 11:16:38 PM
JohnBuckner
Status: online
Possibly the Fairchild 100-A or the American Pilgrim 24A (Fairchild) both of which were capable of those kinds of load. Both had small production runs but have not been able to ascertain if a column or stick was used.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by JohnBuckner -- 5/12/2008 11:17:37 PM >
"Keep your controllines tight"
(in reply to Robinaire)
       Post #: 4
RE: What Fairchild was it? - 5/13/2008 1:01:53 PM
griesel
Status: offline
It was a Fairchild and it had a column. I don't recall it being as ugly as
the 100 or 24A. Is there any way to track down aircraft by registration number?
(in reply to JohnBuckner)
       Post #: 5
RE: What Fairchild was it? - 5/13/2008 1:23:35 PM
griesel
Status: offline
Possibly he as referring to an overloaded condition as it is common now and then.
Full fuel would be about 148 gallons for a 71. This would weigh 910 +/- 52 lbs.
Maximum gross weights for a 71 are listed as 5500, 6000, 7000 pounds depending
on sub model but mainly which engine. Taking the largest version with a gross
payload of 3595 pounds and assuming 200 pounds for pilot and 50 pounds for
arctic survival gear and 962 pounds max for fuel would leave 2383 pounds for
cargo.
       Post #: 6
RE: What Fairchild was it? - 5/13/2008 5:27:01 PM
N1EDM
Status: offline
Do a search on Google for the registration number. That might pop you into the FAA database if the airplane is still listed there.
Bob
An expert is someone who has been doing it for 15 minutes longer than you.
       Post #: 7
RE: What Fairchild was it? - 5/18/2008 3:22:59 PM
khodges
Status: offline
quote:
ORIGINAL: griesel
Searsh "FAA Registry". It will hit on a site where you can look up any registered aircraft in the US by owner's name, N-number, make and type, or state and county of registry.
Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
       Post #: 8
RE: What Fairchild was it? - 5/18/2008 7:31:39 PM
Taildragger726
Status: offline
quote:
ORIGINAL: griesel
http://www.landings.com/
Also known as N726AC
       Post #: 9
RE: What Fairchild was it? - 6/24/2008 10:44:08 PM
Glasair2
Status: offline
Sounds like a 24W. Warner radial powered Fairchilds.....nice!!
http://www.airventuring.org/fairchild/ground1.php
(in reply to Taildragger726)
       Post #: 10
RE: What Fairchild was it? - 6/25/2008 4:28:15 PM
griesel
Status: offline
I looked up Wikipedia Fairchild 24 and with a pilot and fuel, the payload is far less than 1000 pounds.
It is a very nice 4 place plane with generous allowance for luggage, but a 1 ton freight hauler
it aint. It had to be a 71 or its predecessor.
Thank you for the reply.
Dave
(in reply to Glasair2)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.422RCU1
