jollyroger
MI, USA Status: offline
Very nice work Dave! I have also been in the process of building mine off and on for the past two years. I finall covered the tail surfaces and wing with Sig's Aerocote. Not bad stuff really, and it does mold itself around corners very well. A little heat sensitive as there is not too much play in the temp setting before shrinkage occurs. The fuse is nearly finished with just a little sanding and a few pieces. Since this is going to be converted to electric, I will have to establish where the battery tray will be installed, including a hatch. I also opted for dual aileron servos and plan to use a six channel Rxcr for differential control. Specs: Hitec HS-81 / wing servos HS-225BB / rudder and elevator Berg 6/5 Rxcr Hacker A50-12S outrunner Castle Creations Phoenix 60 ESC " " BEC 5S Lipo / Hyperion, Polyquest and Elite you take your pick. My first choice to use will be a new Elite 5S 4800 25C pack I just received from Cheap battery Packs. I do have the others as well and some new Apogee 3800 LiMn packs . Lotsa volts here stay back,! Anyway I need to get this finished and in the air before a friend gets his Midwest Citabria up...Psst, it's been hanging in his basement for three years never flown yet. The most problem I've had is getting the fuse sanded from the cockpit forward to the cowl and getting it to look just right. I'm not too good at this and have had to replace the excess lost balsa and start over again. The Hacker outrunner is good to about 1200 watts so there should be no problem with power.hehehe. Good luck on your maiden and keep the rest of us non finishers informed,LOL
