Furadi
ID, USA Status: offline
quote:
ORIGINAL: jonnymac quote:
ORIGINAL: Furadi quote:
ORIGINAL: MATT55 how do i get a better turning radius on my sportwerks mayhem??? I have a spektrum on it, do i need to do something on the radio to make it better?? Adjust your endpoints. Try a lighter sway bar, add some neg camber, shorten and or lower your front camber links. If none of that helps try reducing your front caster. A $100 servo probably won't help much. I have a 5625 in my 8ight and can cut corners and hold lines as well as anyone else. I'm sorry but a $100 DS1015 servo is the single biggest upgrade you can do to your buggy. NOTHING else changes the handling of a buggy more than that. Now I've never tried a 5625 and don't know what they're like, so yours might be good or not, but the JR590 in a spektrum set isn't up to it. If the servo doesn't have the torque to push the servo straight to its endpoints quickly then your turning radius will be larger. Just use the 590 on the throttle brake, throw away the 577 and put the DS1015 or Sanwa on the steering I hear that all the time. Thing is, buggys have small tires and when there in motion there even lighter. You don't need a $100 servo on a 7lb buggy. Now on a truggy I could understand... and yes, I have driven an 8ight with a 333oz servo in it and aside from setup it didn't feel any different than my 5625. Telling people they need a $100 servo to get better steering is like telling people they need a $300 engine to go faster.
< Message edited by Furadi -- 5/13/2008 8:29:13 AM >
