beer=food
Joined: 11/26/2007 From: hervey bay, AUSTRALIA Status: offline
Air compressor while engine is running blow over it, LOL not the air filter dah, if its got a leak it'll likely stall , and its not normanl for ANY nitro engine to smoke, other than exhaust smoke, check ya clutch isnt fried or frying, and that oil or like someone said WD 40 or RP7 whatever one you use hassnt clagged up with grit on the block, usually that is a sign the heads to hot via lean running, but as you have richened it , it must be something else, either something rubbing or cooking, lol clutch or gunk !
