Nitro Sport Clutch Help
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> Nitro Sport Clutch Help
Page: [1]
Login
Nitro Sport Clutch Help - 5/13/2008 2:57:16 AM
paintfumes
Status: offline
Hey guys I just got done installing an OS 18 cv-r in my sport and fired it up for the first time. The problem Im having is the clutch seems to be engaging all the time. I have my idle set perfect and the slipper set fairly loose but when I lift the wheels off the ground the tires start spinning fast and when I put it on the ground it creeps forward.
If you guys have any suggestions I would greatly appreciate it.
       Post #: 1
RE: Nitro Sport Clutch Help - 5/13/2008 4:18:05 AM
buck in rut
Status: offline
if you are unable to lower the idle anymore you only choice is to go with a stronger clutch springs but im betting once you get the engine broke in and tuned the problem will go away i had the same problem with my rustler but after i got it tuned i was able to lower the idle to the point were it was no longer an issue tighten your slipper back up having it loose wont help any
(in reply to paintfumes)
       Post #: 2
RE: Nitro Sport Clutch Help - 5/13/2008 4:26:58 AM
dittch
Status: offline
you may have installed he clutch shoes wrong when you transfered over the assembly. Pull the clutchbell and make sure they're installed correctly
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.250RCU1
