Resonator pipe causing problems
Tower Hobbies
Logged in as Guest
  Printable Version
CEN Racing Genesis Monster Truck - RTR - RTR
Seller:  solidgold5
Details:   $250.00   |  7/15/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> Resonator pipe causing problems
Page: [1]
Login
Resonator pipe causing problems - 5/13/2008 3:10:06 AM
capew246s
Status: offline
After breaking my new Revo 3.3 engine in I decided to upgrade to the Traxxas Resonator pipe. I had only leaned the HSN a bit while my stock pipe was on. I richened the HSN a bit and bashed around with it to see how the Resonator worked before trying to tune it anymore.
Not long into running it I had problems. The most apparent problem was with the idle. It kept dieing and/or wanting to die when it came to an idle. I took it out today to get it tunned in nice but it didn't want to start and/or stay running when it did start. I got a lot of white smoke when it did fire up, that has me worried. I thought maybe it's from the WD40 but I wasn't sure.
So the problem is that my 3.3 won't start and stay running and that's accompanied with abnormal amounts of white smoke. Anyone have a clue what's up?
       Post #: 1
RE: Resonator pipe causing problems - 5/13/2008 3:57:06 AM
matts6887
Status: offline
Sounds like the addition of the resonator kinda threw off the needle settings. If I were u imo, I would try re-setting the needles back to factory and re-tuning it from there. If u can't get it to fire initially, make sure to check the plug to make sure the plug is still good; because it is possible that the break-in period finally did the initial plug in....I might want to try a new plug in addition to re-setting the needles to see what happens.....either way good luck with it man...
_____________________________
"If U havent broken anything....U arent driving it hard enough"
(in reply to capew246s)
       Post #: 2
RE: Resonator pipe causing problems - 5/13/2008 4:01:37 AM
capew246s
Status: offline
I checked the plug and it glows hot. It was getting colder so I'm crossing my fingers that the temp outside was making things tough. I'll give it a try tomorrow and hope for the best.
(in reply to matts6887)
       Post #: 3
RE: Resonator pipe causing problems - 5/13/2008 11:52:45 AM
RCCanuck
Status: offline
yeah your needles are off...with the addition of the new pipe and the colder temps you will need to retune.
2.5 Tmaxx// T Maxx-Picco.26//2.5 Race Spec maxx//Savage SS//Brushless Micro T's//Micro DT ...all controlled by Spektrum
       Post #: 4
RE: Resonator pipe causing problems - 5/13/2008 8:48:36 PM
ENZO7
Status: offline
I would raise you idle speed a little to see if it will set and idle...
T-Maxx 2.5 With Pull Start, RPM Arms, Big Bore Shocks, Motor Saver Filter, and a VG Roll Cage
(in reply to RCCanuck)
       Post #: 5
RE: Resonator pipe causing problems - 5/14/2008 1:42:08 PM
capew246s
Status: offline
I was able to get it running and I've got it going pretty good now. The only trouble is the LSN and the idle aren't getting along. I'm also getting some issues with shifting but I think that'll work out in the end when I get all the tweaks correct.
(in reply to ENZO7)
       Post #: 6
RE: Resonator pipe causing problems - 5/14/2008 4:24:44 PM
matts6887
Status: offline
Well, once u are sure u have the idle set correctly, go back and re-adjust the lsn until ya think u have gotten all the "kinks" worked out of it.
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.703RCU1
