sport tuned motor in clod buster?
Tower Hobbies
Logged in as Guest
  Printable Version
Megatech Afterburner Funny Car RTR
Seller:  Erick Royer
Details:   $275.00   |  5/26/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> sport tuned motor in clod buster?
Page: [1]
Login
sport tuned motor in clod buster? - 5/13/2008 4:26:21 AM
xism
Status: online
i just got a super clod and is going to upgrade the motors. now, the tamiya sport tuned looks nice but how will they work? (one must be in reverse?) i have no idea about those motors maybe someone has some experiences? thnx
       Post #: 1
RE: sport tuned motor in clod buster? - 5/13/2008 4:34:41 AM
hollylx88
Status: offline
i had one in my t3 for the longest time. it got alot of abuse and little care. and it ran till i pulled it out just recently to upgrade. so as far as longevity goes, i had great luck with mine, i'm just not sure what to recommend for your specific application though. if it needs to be reversed, you can just switch the wires, that's not a big deal. but whatever motors you're going with, if one needs to be reversed just make sure there's no timing advance on them (as in 0 degrees advance)
_____________________________
wa wa woo wa!
(in reply to xism)
       Post #: 2
RE: sport tuned motor in clod buster? - 5/13/2008 5:21:23 AM
AutoXMan
Status: offline
Sport Tuned motors have fixed advanced timing. It will not work with the Clod.
(in reply to hollylx88)
       Post #: 3
RE: sport tuned motor in clod buster? - 5/13/2008 3:30:13 PM
oldschool77
Status: offline
Hey Auto...can you explain what that means?
(in reply to AutoXMan)
       Post #: 4
RE: sport tuned motor in clod buster? - 5/13/2008 4:06:11 PM
AutoXMan
Status: offline
In simple terms a motor with advanced timing is slightly faster than the same motor with 0 degrees timing. However the advanced timing will run faster in forward than reverse. In a Clod, I am led to believe that the 2 motors have to be mounted in 2 separate directions. If sport tuned motors were used the one mounted in the forward direction would be running fine and dandy, however the other would be severely slower than the forward mounted one. Much slower than a regular ole silvercan.
A sport tuned motor is a 27 turn motor with advanced tioming (fixed) while the silvercans are 27 turn motors with 0° timing.
You can think of it this way, advanced timing = faster forward speed and lower reverse speed.
(in reply to oldschool77)
       Post #: 5
RE: sport tuned motor in clod buster? - 5/13/2008 7:21:34 PM
drevil
Status: offline
quote:
ORIGINAL: AutoXMan
True.
When turning the endbell (the part the wires attach to) of the motor in relation to the motor can in one direction or the other you're changing the timing of the motor. Some motors like the stock silvercan motors that come with the Clod have 0 degrees timing. Other motors like the sport tuned have advanced timing. The problem is that when you advance the timing on a motor it's only advanced in one direction, which means when you drive in reverse the timing is retarded. (negative) With the Clod you have to run one motor running in forward rotation, and one in reverse rotation. Since the sport tuned motor is locked at 27 degrees advanced timing that means one motor will have 27 degrees advanced timing and the one running in reverse will have 27 degrees retarded timing. For that reason you must either get a motor with 0 degrees timing or adjustable timing.
< Message edited by drevil -- 5/13/2008 7:22:25 PM >
Mike
R/C Truck News - http://www.clodzone.com
       Post #: 6
RE: sport tuned motor in clod buster? - 5/13/2008 11:45:34 PM
xism
Status: online
yep, i was afraid of this :P thnx anyway btw i believe the sport tuned is 23t not 27.... my clod camed with mabuchi 540 instead of the more powerful(?) johnson's. the bullhead came with the "4 slot johnson" - a more powerful motor. I could get the 540-J motors to my clod but i dont believe it will be that much faster
(in reply to drevil)
       Post #: 7
RE: sport tuned motor in clod buster? - 5/14/2008 12:12:39 AM
drevil
Status: offline
23 turns and 27 degrees of timing are two different things.
Mike
(in reply to xism)
       Post #: 8
RE: sport tuned motor in clod buster? - 5/14/2008 12:30:24 AM
AutoXMan
Status: offline
The sport tuned motor IS in fact a 27 turn motor with advanced timing.
       Post #: 9
RE: sport tuned motor in clod buster? - 5/14/2008 1:51:41 AM
xism
Status: online
well, the sport tuned motor comes with both 23 AND 27 turn...
       Post #: 10
RE: sport tuned motor in clod buster? - 5/14/2008 5:47:45 AM
Longhair
Status: offline
quote:
ORIGINAL: xism
Link please?
We never live through the lives that we have chosen.
(in reply to xism)
       Post #: 11
RE: sport tuned motor in clod buster? - 5/14/2008 6:06:10 AM
AutoXMan
Status: offline
Maybe he is talking about the Tamiya RZ motors and such I have heard older sport tunes have been rumored to be 23 turns, but this was all speculation and it doesn't matter as all new ones are 27.
(in reply to Longhair)
       Post #: 12
RE: sport tuned motor in clod buster? - 5/14/2008 10:37:28 AM
xism
Status: online
i googled, and finded some info at a forum... 23t is available in europe, and the 27t version in asia
http://www.tamiyaclub.com/forum/lofiversion/index.php?t34778.html
also someone at ebay is selling a 23t version: http://tinyurl.com/4dscxf
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
