BryFlyGuy67
Joined: 8/27/2007 From: Grand Rapids, MI, USA Status: offline
quote:
ORIGINAL: aland25 Ok, the heat shrink is still on the ESC. I picked up a IR Temp. gun at AutoZone for $19.99. Just completed my first test with a 2200mAh battery, hovered for 7 min flat and here are the results: (I scanned immediately after flight) Battery - 95 degrees max Motor - 135 degrees max ESC - 160 degrees max *(Max temperatures are indicated and decrease from that mark) Please let me know if this is normal...Thanks IMHO, the LiPo temperatures are fine, but your motor and especially the ESC are too hot. Again, on my 100% stock V2, motor temps after 8 min of hovering and slow FF are only 105F and that is with no heat sink on the motor. My ESC temps are right around 105F after flight as well. On the ESC, you have the heat sink mounted so that the cooling fins are UP, right? Tell us about the rest of your setup. What servos do you use? I'm just wonderng if the extra heat buildup might be due to the internal BEC... The motor temps can probably be managed with a heat sink, but you definitely want to find out why it and the ESC are getting so hot. What are the outside temperatures when you have been flying?
_____________________________
Flying may not be all plain sailing, but the fun of it is worth the price. -Amelia Earhart 2 CX2s, Walkera 4, TREX SE V
