G2300, runs perfect, but wont stop running!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> SuperTigre Engines Support >> G2300, runs perfect, but wont stop running!
Page: [1]
Login
G2300, runs perfect, but wont stop running! - 5/13/2008 6:15:10 AM
JohnVH
Status: offline
How do I make it shut off? haha, I realize this sounds odd, but dang, the thing will idle all day with the throttle barrel closed, on top of that, I even pinched the fuel line, and it idled great for another 30 seconds! Never had one that I couldnt shut down.. any idea's? The motor is brand new, has a perry carb on it, and runs awesome!!!
help? lol
_____________________________
---AIR VH---*FURY FLYER* www.3DFoamy.com
       Post #: 1
RE: G2300, runs perfect, but wont stop running! - 5/13/2008 3:47:56 PM
Bax
Status: offline
When an engine will not cut off by closing the carburetor, it usually means that the air isn't cut off fully. Many carbs leak air and fuel even when closed. You'll have to carefully check to be sure all air leaks are gone. If there's air in the fuel line, it can also allow an engine to continue to get fuel. You may also have to lean the idle mixture. When the engine continues to run for quite a while after you pinch off the fuel line, it means that the engine is still has a lot of fuel in the crankcase. That would result from a too-rich idle setting.
Please note that we deleted other posts in this thread because they were not from SuperTigre reps, and were also more in the nature of a discussion. Both are not permitted by RCU rules.
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
(in reply to JohnVH)
       Post #: 2
RE: G2300, runs perfect, but wont stop running! - 5/13/2008 4:18:02 PM
JohnVH
Status: offline
Still too rich, ok, when it stops raining Ill give it another shot. Ill try to silicone up the carb to engine, as I have the rubber O ring squished in there. I dont know how else to cure it. Unless I just throw a towel in it to stop it every time..
(in reply to Bax)
       Post #: 3
RE: G2300, runs perfect, but wont stop running! - 5/18/2008 11:38:48 PM
JohnVH
Status: offline
ok, just update, I siliconed the carb into the case, now I can kill it, but its lost its easy tuning, haha.. I may try to scrape off the silicone and just figure a new way to kill it.
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.641RCU1
