How to heat up engine in the field?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> How to heat up engine in the field?
Page: [1]
Login
How to heat up engine in the field? - 5/13/2008 7:43:42 AM
kweezinarts
Status: offline
at home i use my fiance's hair dryer which is 1875watts but was looking at a 1000w heat gun both of which need a fairly expensive DC to AC inverter.
is there any way to get around this besides running at a place with AC power or a generator? i have acces to a small generator but it seems like a huge PITA to have it going/starting it for 1 hair dryer for 5 minutes...
< Message edited by kweezinarts -- 5/13/2008 7:44:35 AM >
_____________________________
NRusty 2.5 - TTR ST-1 w/ JPX.28 - Walkera Dragonfly #4
       Post #: 1
RE: How to heat up engine in the field? - 5/13/2008 11:49:53 AM
Argess
Status: offline
I read somehwere that one of those tire-warmers work well to pre-heat your engine, and they run on batteries.
I've used a hot-water bottle before. Just a zip-loc bag full of hot water and sat it on the head. You can take hot water with you in a thermos.
< Message edited by Argess -- 5/13/2008 11:50:37 AM >
(in reply to kweezinarts)
       Post #: 2
RE: How to heat up engine in the field? - 5/13/2008 1:09:22 PM
RevToTheRedline
Status: offline
My main question is why are you relying on heating the engine up so much? The only thing I've really thought of needing it has been during break-in, is your starter box not able to handle your motors pinch even after break-in so you have to heat it up?
Mugen Seiki MBX5R : RB C6BBT II L2G w/ RB 2045 : Futaba 3PKS 2.4Ghz Fasst : Ace 1015/1313 : Lots of weight reduction mods
(in reply to Argess)
       Post #: 3
RE: How to heat up engine in the field? - 5/13/2008 1:53:39 PM
hrdcoreglf
Status: offline
Even after break-in for atleast the first gallon or so, the pinch puts a lot of stress on con rod and other internal engine parts. It helps to reduce the wear if your engine is up to temp before you start it.
Wisdom is only as good as the person you give it to.
(in reply to RevToTheRedline)
       Post #: 4
RE: How to heat up engine in the field? - 5/13/2008 1:56:27 PM
Argess
Status: offline
Only time I heat mine, is when I want to start it outside in winter temps. Makes it a lot easier to start. But typically, once outside, I just try to start it quickly, or sometimes start it inside, and then take it outside, which usually meets with complaints.....LOL.
Anyway, he asked......and he got a few answers.............
(in reply to hrdcoreglf)
       Post #: 5
RE: How to heat up engine in the field? - 5/13/2008 1:57:04 PM
luigi410
Status: offline
my engine is 6 months old and i still warm it to get it to start easier. i usually leave the glow plug in for 3 to 5 minutes before starting, works most of the time when i thrash outdoors. doesn't work when its too cold though
I love the smell of nitro in the morning!
       Post #: 6
RE: How to heat up engine in the field? - 5/13/2008 3:27:56 PM
cam3r0n
Status: offline
How about a portable hairdryer that pugs into your car lighter socket? You might even be able to bodge it off your starter box battery:
http://www.waudbys.co.uk/products/details/15204.html
Think outside what box?
       Post #: 7
RE: How to heat up engine in the field? - 5/13/2008 4:29:17 PM
kweezinarts
Status: offline
good thinkin cam3r0n...
i need to heat it up in the field because its a jammin .28 ( 6-7 tanks through it) with a tight pinch and i would like to run it somewhere besides outside my house (big blocks are loud)...
thnx for input all...
(in reply to cam3r0n)
       Post #: 8
RE: How to heat up engine in the field? - 5/14/2008 3:22:26 AM
TRINI-LUCIAN
From: TunapunaTrinidad and Tobago, TRINIDAD AND TOBAGO
Status: offline
if day temps are over 80 just leave it in the sun on the tarmac surrounding the track for about 10 mins.... where i live its hot year round and i tried this technique...works i guess.....the engine starts alot quicker, sometimes on the 5th pull, as compared to late in the evening
I dont drive....I fly low!!! :)
(in reply to luigi410)
       Post #: 9
RE: How to heat up engine in the field? - 5/16/2008 12:16:36 AM
Jatohulk
Status: offline
By pre-heating the engine with a heat gun or hair dryer you will extend the life of the engine than just starting it up from a cold start.. It creates less stress in the internal parts of the engine. I have try both and found pre-heating it is better but it is one more step to do when running at the track.. I live in FL and still pre-heat my engine all the time now..
IT'S ALL FUN AND GAMES UNTIL YOU SMACK INTO THE WALL AND BRAKE SOMETHING!!!!!!!!!
(in reply to TRINI-LUCIAN)
       Post #: 10
RE: How to heat up engine in the field? - 5/16/2008 5:41:44 AM
kweezinarts
Status: offline
true, luckily most tracks have power in the pits, but my problem lies when i need to go to a bash spot. i did find a few 12v hair dryers but of course the wattage is low so i wonder if they will provide enough heat to do the trick...
(in reply to Jatohulk)
       Post #: 11
RE: How to heat up engine in the field? - 5/16/2008 6:21:46 AM
UG0TB4NN3D
Status: offline
Focus the sunlight on the head. Haha.
<s>Jammin'''''''' X1 CRT Pro, BCE PJX Chassis + Small Spur mod, Ninja .28 Powered, Spektrum DX 2.0M</s> - <b&
       Post #: 12
RE: How to heat up engine in the field? - 5/16/2008 6:28:48 AM
kweezinarts
Status: offline
that or rub my hands together REALLY fast like mr miagi and lay them on the engine
(in reply to UG0TB4NN3D)
       Post #: 13
RE: How to heat up engine in the field? - 5/16/2008 6:36:35 AM
UG0TB4NN3D
Status: offline
Lmfao.
I'm sure a bit of nitro and some matches would work. :]
       Post #: 14
RE: How to heat up engine in the field? - 5/16/2008 12:43:23 PM
Jatohulk
Status: offline
guys the jokes are very funny but you are not helping the guy at all.. I only run my Cars at the track so I can not really help you when you go to bash around..
