Should I run them dry?
Tower Hobbies
Logged in as Guest
  Printable Version
CEN Racing Genesis Monster Truck - RTR - RTR
Seller:  solidgold5
Details:   $250.00   |  7/15/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Should I run them dry?
Page: [1]
Login
Should I run them dry? - 5/13/2008 8:44:20 AM
systemlord
Status: offline
Hi everyone,
I own 8mm titanium CVD's (pic show steel) and have just disassembled to clean them as I do every season, I have some excellent quality grease (Gorilla Dnawt) and was wondering if I should go ahead and lube them? If I can increase the life of my CVD's then it sounds like something I would do, btw I do use rubber CVD booties to seal them. So will this really increase the life of my CVD's?
Click to see fullsize image.
Click for fullsize
_____________________________
UE SuperMaxx 1/8th Monster Truck* Custom Duratrax Vendetta Mamba 25 Motor 5400kv Impulse 3S1P 11.1v 950mAH 25C * Raptor 60
       Post #: 1
RE: Should I run them dry? - 5/13/2008 8:52:37 AM
Foxy
Status: offline
Boots are always a good idea. Anything you can do to prevent dust getting in there will help extend their life. Titanium is not as hard or as strong as steel (thickness for thickness), so it will be important to keep contaminants out.
Lubing with a grease may not be a hot idea, as dirt and dust will stick to the grease, and wrk it's way into the CVDs moving parts, causing premature wear. If you do decide to grease them, the boots will be even more important. I'd say if you really want to increase their life, use graphite dust and boots. Graphite dust is a dry lube and will not attract dirt.
At the end of the day though, no lube of any kind and no boots is how most people run them. I don't know how much extra life you might get out of them by lubing and using boots. Not much, I would imagine, but if you're one of those people that likes to take every precaution, go for it.
Foxy. RCU Car Forums Moderator.
These opinions are my own and may not represent the views of RCUniverse.com
Check out my Large Scale Gas RC Car Vids... www.youtube.com/foxy4242
(in reply to systemlord)
       Post #: 2
RE: Should I run them dry? - 5/13/2008 9:40:25 AM
systemlord
Status: offline
quote:
ORIGINAL: Foxy
Thank you for that very helpful reply! The only reason I can think of why others don't you booties and/or dry type lube is because you can always spray a high pressure air hoes to shoot out the dust and dirt after running. Using booties can be a curse as well, if dirt does get in there and you don't know about it... I'm still thinking weather I should just run them as they are so I can clean them out at will without having to disassemble. Well the way I've been doing it for over two years has been working out, theres no visible wear anywhere on the barrel & pin. Not even a smooth scratch.
< Message edited by systemlord -- 5/13/2008 9:44:21 AM >
(in reply to Foxy)
       Post #: 3
RE: Should I run them dry? - 5/13/2008 10:28:35 AM
Foxy
Status: offline
I'd say keep going as you are then. If it ain't broke, don't fix it!!
       Post #: 4
RE: Should I run them dry? - 5/13/2008 10:48:13 AM
systemlord
Status: offline
I will always use booties, I will be trying some Graphite dust so not to atract dust. I''ll just have to check to see what condition the booties are in often.
(in reply to Foxy)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.688RCU1
